Old 05-22-2004, 05:25 PM
vze24x2x vze24x2x is offline
Default Laying Back Mixes to a DA88 WTF?
I'm wondering if anyone out there has been doing this on a regular basis. It seems like it shouldn't be this difficult. I have a sync i/o & 2 192's. I want to lock the protools system to Black Burst via the 'Video Ref In' jack, then lock the DA88 to the sync i/o via the 'Word Clock Out" jack. no go. why?
It seems that there is simply no Word Clock signal coming out of that particular jack. Oh, I've already given up on connecting TDIF directly to the 192, I don't know why it would even be there if it doesn't work. I'm using an IF88-AE and connecting to the AES side of the Digital i/o. The only way I've been able to lock everything together is by Genlocking my Aardsync to black burst, then connecting word clock out of the Aardaync to the 'Word Clock In' of the Sync i/o and a second output of the Aardsync to the wordclock in of the DA88. I'd like to streamline this a little more, How does everyone else do this kind of thing? any help would be appreciated.
-BK
Old 05-22-2004, 06:34 PM
DigiTechSupt's Avatar
Default Re: Laying Back Mixes to a DA88 WTF?
Yes, this can be tricky. You need to use the word clock output of the 192 I/O NOT the Sync I/O, believe it or not, and then in the hardware setup window, set the "Ext. Clock Output" setting to "Word Clock (TDif)".
There is also an Answerbase entry for this, check ID:7981 for more info.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 05-23-2004, 02:31 PM
Hi Jon,
Thanks for replying. I saw your posts from a couple of years ago on this subject and tried what was reccomened and it didn't work. to keep things simple I left out the Black Burst side of the issue. I had a TDIF cable going from the 192 to the TDIF i/o of the DA88. Ext out Word clock set to TDIF and a BNC cable going from the Ext Clock out of that 192 to the word clock input of the DA88. I put a BNC 75 ohm terminator on the word clock out jack of the DA88 (I did not use the BNC T). Selected the 192 as the clock master and selected "wordclock" as the clock source on the DA88 and....... nada. it no workie. So can you see anything wrong with what I'm doing? it couldn't be that little BNC T could it? This scenerio as I said earkier, didn't include the Black Burst side of the equasion. now how would you genlock this rig to video and still maintain the sync set up using the 192? Provided it actually would work.
-BK
Old 05-23-2004, 07:40 PM
You can keep the Sync I/O as the clock master (and therefore blackburst) of the system but you must use the Word clock output of the 192 I/O NOT the Sync I/O for your Tascam, even if the Sync I/O is in the system.
It sounds like you have everything setup correctly. At this point, if you haven't already, you should check with that Answerbase entry I mentioned in my previous post. It covers this fairly well from what I recall.
Other than that, have you tried?...
- a different BNC cable from the 192 to the Tascam?
- a different Tdif cable?
- powering everything down, restarting and trying it all again?
If none of this helps, you may want to give Digidesign Tech Support a call on Monday, 650-731-6300.
Jon Connolly
Support FAQ
Old 05-24-2004, 07:24 AM
Jeff_Francis Jeff_Francis is offline
BK,
I see your problem. The additional termination needs to be on the Word Clock INPUT of the DA-88, not the output. Putting a terminator on the output doesn't change how the DA-88 receives sync. A BNC 'T' is the easiest way to accomplish this. This is an idioSYNCrasy of the DA-88.
Hope this helps,
JF
Old 05-24-2004, 10:17 AM
Aquarius Aquarius is offline
hello !
Does this setup apply only to DA 88's ?
How is the WC out of the Sync outputting to other machines ?
Peace,
Olivier
Old 05-24-2004, 12:44 PM
Noiz2 Noiz2 is offline
THe T connector and terminator is required for the DA-78 also, so I suspect it's true for all of the series. Also the word clock is supposed to be a 50 ohm cable and terminator not 75 ohm, at least on the 78.
www.scottkouesound.com
SK
Old 05-25-2004, 11:17 AM
Well I just put in the BNC T and terminated the input instead of the output and lo & behold, it works. thanks for the help guys.
-BK
Old 05-26-2004, 09:55 AM
I just checked with my notes from the Tascam site (really a good resource) and it should be 50 ohms. But if your set up is working I wouldn't touch it. Just an FYI if you issues in the future.
SK
Old 05-26-2004, 01:23 PM
Thanks Noiz2,
How do you think tascam reconciles the fact (i think it's a fact) that one company considers 75ohm cable to be the standard (Digi) and another considers 50ohm to be the standard (Tascam). it is working, but which standard is the 'right' standard?
BTW, I just looked at Tascam.com and they don't even have the DA88 listed in any of their catagories. is there some kind of secret archive you're accessing?
-BK
HTML code is On
Laying out mixes on a console snakebit macOS 11 09-12-2013 08:09 AM
Laying back at 24p to HDCam SR? Cheesehead Post - Surround - Video 13 02-28-2011 03:36 AM
Laying back to Tape Peter Groom Pro Tools TDM Systems (Mac) 0 02-08-2007 06:34 AM
Laying back to HDW F-500 bryston Post - Surround - Video 12 01-08-2007 12:13 PM
Laying Back to Digibeta? HiRaX Post - Surround - Video 11 01-06-2006 07:41 AM
