Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-07-2024, 03:18 AM
wickett wickett is offline
Default Re: Pro Tools not seeing Carbon
Thanks. I have removed carbon central.
I've also reset the firmware + reinstalled HD drivers a few times now.
I get an error message when starting Pro Tools saying it cannot communicate with the carbon. It asks me to select the audio device in Hardware setting but the carbon is not in the list even though the system can see it and it is detected and ticked in Audio/midi setup.
I restarted Pro Tools. while holding down the 'n' key and I was able to select the carbon in the hardware list. Not sure if this was because I held down the key or because I restarted Pro Tools.
ISome times when I power the carbon of and on or restart pro tools It works again but after I restart my mac I get the same problem again
Old 09-07-2024, 04:41 AM
The 'N' key does the trick until I restart my Mac. Then the same issues occur.
Old 09-07-2024, 11:35 AM
massivekerry's Avatar
massivekerry massivekerry is offline
I'm completely spitballing here, but I believe you do not need the HD drivers if you're using Carbon. I got a new computer when I bought my Carbon and have studiously avoided the HD drivers since then. Maybe (fully?) remove them?
Kerry Smith
http://apothekerry.com
Mac Studio M1 Ultra : 128GB RAM : Ventura 13.6.6 : Carbon : PT Ultimate 2024.6 : S1 : Metagrid Pro
Old 09-07-2024, 11:44 AM
Correct, HD Drivers are totally unneeded, they are for HD Native and HDX only.
Old 09-07-2024, 01:37 PM
dominicperry dominicperry is offline
I then Re-install the carbon central app and it 'sees' the carbon is an expansion unit.
I think this might be the problem. Have you accidentally designated your Carbon as an Expansion unit rather than Primary? I'm not sure how you'd manage this if you only have one unit, but Carbon Central is the place to assign this value.
Sounds like you might need to re-install Carbon Central, change that value and then try again.
The other boring but worthwhile thing to do when troubleshooting connectivity problems is try another known good (Ethernet) cable.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.7, Pro Tools 2023.12.1, Carbon.
  #16
Old 09-07-2024, 03:41 PM
K Roche's Avatar
K Roche K Roche is offline
This is could be your problem. Carbon does not use HD drivers
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.6.1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #17
Old 09-09-2024, 08:14 AM
I've uninstalled the HD drivers.
I reinstalled carbon central and checked that it was not configured as an expansion unit.
Same issue occurs.
Uninstalled carbon central again.
Same issue occurs.
Tried other known good ethernet cables.
Same issue occurs.
Thanks anyway.
Thanks anyway.
  #18
Old 09-09-2024, 08:16 AM
Same issue after uninstalling the drivers.
2 weeks of this and I'm now looking at good old RME interfaces.
Sigh..........
  #19
Old 09-09-2024, 08:41 AM
After connecting the carbon by holding the 'N' key I got the AVB internal error AAE -6123
  #20
Old 09-09-2024, 10:52 PM
[email protected] mradlauer@gmail.com is offline
No one asked, and I don't see it in your posts..
What are the specs of your computer. You said Mac.. but Macbook/Pro? Mini? Studio?
If you're on a macbook what ethernet interface are you using?
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
NEW -> Pro Tools | Carbon Pre tetonica Pro Tools | Carbon 94 11-10-2022 02:30 AM
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
