Old 08-16-2024, 09:10 PM
Default Re: Sonoma 14.6
I've been running Sequoia since the first developers release. No direct issues with anything to do with Pro Tools. But I've seen multiple bugs with Systems Settings, C compiler (may not be new), audio "mic" settings bugs (may be resolved), I've filed at least three complaints, should have filed more. But Pro Tools 2024.6 and nearby releases working seemingly OK for me here is in very different contrast to Sonoma which had major issues with the then current Pro Tools when it was in beta and first released.
However I would definitely not extrapolate those experiences to just consider Sequoia "safe to install on day one." Lets wait and see. I also personally don't say use Pro Tools with video, run Avid control surfaces, and don't run with hundreds and hundreds of plugins. I have no rack of Avid MTRX and not 192 fader S6 etc. so my own experience is not that helpful for many critical users.
Old 08-17-2024, 01:35 AM
JFreak's Avatar
JFreak JFreak is offline
Good perspective
Janne
Old 08-17-2024, 11:02 AM
Eric Lambert's Avatar
So often on this forum an errant plugin is found to be the culprit of whatever issue the user is experiencing. We tend to treat that folder as a closet -- just throw everything in there. But over time it becomes a toxic wasteland, and a single bad/outdated plugin can plug up the whole system. Management of that folder is essential for smooth PT and other apps.
Old 08-20-2024, 08:09 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Installed 14.6.1 yesterday - started getting 'Protools failed to stop' errors .. maybe unrelated .. but it was working fine prior. However the sessions I was recalling did have some older plugs using rosetta.
http://www.ainsliegrosser.com/
MacBook Pro M3MAX 16 Core 64GB OSX 14.6.1, HDX, Sonnet Chassis, PT Ultimate 2024.6.0, S3, Dock, MTRX Studio, Atmos to 7.1.4 monitoring
Old 08-20-2024, 09:12 AM
JFreak's Avatar
Always check for new plugin versions after updating. Rogue plugin is the worst problem.
Janne
  #16
Old 08-21-2024, 08:58 PM
basslik's Avatar
basslik basslik is offline
Okay I just installed Sonoma 14.6.1 on a separate container I share with Monterey.
Was stoked I was still able to install the digi 003 driver using junichiro's process.
I'll see how this puppy stands up.
MAC PRO 2010 5,1 3.46hex 128ram -CONTAINERS / SEQUOIA 15.5 / MONTEREY 12.7.6 & SONOMA 14.6.1 - PT 2024.10.2/ 003 RACK BLA SIGNATURE MOD / DIGI 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #17
Old 08-22-2024, 04:09 AM
Gemylon's Avatar
Gemylon Gemylon is online now
Please elaborate 😎
MacBook Pro M2 Max / Pro Tools 2024.10 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
  #18
Old 08-22-2024, 06:13 AM
AINSLIE's Avatar
Fresh built system will all latest versions ... just addicted to like 2-3 plugs that are getting long in tooth and won't be upgraded to silicon - Echo farm to name one throwing up errors. Gotta move on but a ton of mix revisions to do first so rosetta for the moment while I wean myself off it ...
  #19
Old 08-22-2024, 08:40 AM
JFreak's Avatar
I gave up on Echo Farm years ago, seemed to be more trouble than worth
Janne
  #20
Old 08-22-2024, 05:48 PM
basslik's Avatar
Originally Posted by Gemylon View Post
Please elaborate ��
Monterey running smooth with OpenCore 1.5.0, but I wanted to see if I can still keep the digi 003 rack going with version driver 11.1.5. and try Sonoma.
The last version that I'm aware of was Big Sur. So I thought I might as well create another container with Sonoma and I was able to install the driver 11.1.5 without a hitch, ( WOW )
There's no video out there past Big Sur for the Digi 003. But this video works.
https://www.youtube.com/watch?v=F0jq8CXJRBU
Sonoma 14.5 Redpony macOS 29 07-17-2024 12:18 AM
No HD-IO on MacOS Sonoma 14.4.1 mikes-music Pro Tools HDX & HD Native Systems (Mac) 4 05-09-2024 11:56 PM
Artist Mix- Sonoma pasanta Artist Series 2 04-23-2024 03:28 PM
Mac OS Sonoma crashing PT bonkmp Pro Tools 8 12-26-2023 05:41 PM
M3 MBP and Sonoma question francois macOS 5 12-03-2023 07:07 AM
