Old 12-29-2023, 04:44 AM
MDGenerato MDGenerato is offline
Default Re: cannot import video
Originally Posted by The Weed View Post
Went back to 2023.6. All seems good with importing a video and video window sizes, including with Windows Configurations in a session created after installing 2023.6. However, I tried importing the same video into a session created in 2023.12 and...I get a video window, but no video was imported. Strange.
Hi! If this issue still occurs on the latest version, the best you can do is create a case so we can investigate this. Please create a case here:
https://www.avid.com/learn-and-suppo...-music-support
Afterward, please message me with the case number so we can bump it up to our support team. Thanks!
Old 12-29-2023, 09:19 AM
marianna's Avatar
marianna marianna is offline
The Weed
Urge you to create a case so support can look at it and see what might be wrong.
Login to your Avid Account at account.avid.com and select under My Support >Access the Support Center (Portal)
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 12-29-2023, 10:55 AM
The Weed's Avatar
The Weed The Weed is offline
MDGenerato and Marianna, great to see Avid so involved on the DUC.
After some more work, I suspect at least some of the issues are pilot error. I'm going to reinstall 2023.12 and do some more testing and will report back. No need for a support case just yet.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-29-2023, 11:04 AM
marianna's Avatar
Thanks for the nice comment. Please do let us know and if you post and we dont see it - you can also email me direct at [email protected] as well.
Happy New Year!
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 12-29-2023, 06:20 PM
The Weed's Avatar
I'm on Windows 10, PT Studio. I haven't had any issue deleting a video track and importing a new one in either 2023.6 or 2023.12.
The blank video track I mentioned in a previous post was indeed pilot error.
However, in 2023.12 I have had the problem of the video window size not being remembered, something like this thread.
Work flow in 2023.6:
I have a Template for reading to video with Window Configurations for placing Markers, proofing, video size and for my 15.6 inch laptop which I use in my booth to remote control my desktop computer, control Pro Tools, and, of course, see the video and its timecode. When I create a session from my Template and import a video, the video window is the correct size and in the correct place. When I connect remotely to my laptop and change to the "Laptop Remote" Window Configuration my video window changes to the correct size and position for my laptop screen. When I disconnect the laptop and go back to my desktop, and its 29 inch 21:9 screen, I just have to change to the "Video Size" Window Configuration and the video window goes back to the correct size and position for my desktop screen.
In 2023.12, while initially all seems good when creating a session from my Template, once I've connected to my laptop, used "Laptop Remote" and then gone back to my desktop, no Windows Configuration will get the video window back to the correct size and position it originally started in.
Since there's nothing in 2023.12 that I can't live without, I'll stay at 2023.6 and keep checking any future updates.
SonoBus
  #16
Old 09-08-2024, 12:04 AM
PeMotion PeMotion is offline
Default Re: cannot import video - PT Studio 2023.12.1
Hi, I am having the same issue.
  • I don't have the option to create a blank Video track when using the Create Track menu
  • When I try to import a video through the Import menu as an mp4 I get a blank video preview window and a video track was created but I see no data on either the audio or video track. After some research it seemed I had to make the video a .mov file
  • Did that using Quicktime but when trying to import through the Import menu I get the message that only PT Ultimate supports HEVC or H.264 format.
Sorry if I'm being a bit of a noob with video files in ProTools.... any help would be appreciated.
System
Mac OS running Ventura 13.6.3.
2.3 GHz Quad-Core Intel Core i7
32 GB 3733 MHz LPDDR4X.
GPU - Intel Iris Plus Graphics 1536 MB
PT Studio 2023.12.1
Motion
Mixer. Knob twiddler. Not an expert.
https://soundcloud.com/paulemotion
  #17
Old 09-08-2024, 03:26 AM
its2loud its2loud is offline
Download Shutter Encoder
Convert to DNXHD 36
Import into Pro Tools.
  #18
Old 09-09-2024, 08:31 PM
tope d's Avatar
tope d tope d is online now
System
PT Studio 2023.12.1
I've started a support case for you under case 04860553
One of the techs will be in touch.
For now, have you already tried later Pro Tools versions?
Have you also tried converting your video to the proper formatting?
https://avidtech.my.salesforce-sites...e-Type-Support
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Video Import Won't import linked Audio bifbangpow Pro Tools 10 05-30-2023 06:42 PM
Protools won't import audo on video import tonyw7 Pro Tools 14 01-04-2023 11:37 AM
Video Import - Audio longer than video - help please anguswoodhead Post - Surround - Video 5 12-23-2019 01:35 AM
Pt 2018.7 can't import video or open a session with video in it Jeffrey Talbot Post - Surround - Video 10 10-10-2018 01:09 PM
Import Video - Audio Import Option Disabled sarcanon Pro Tools 12 2 06-14-2016 05:12 PM
