Old 11-15-2006, 07:16 PM
Average_Joe Average_Joe is offline
Default OSX Midi Controller Not Seen on Input
I Have a Mac Mini With my Yamaha Motif 6 Connected trough USB. (i am using an Mbox 2) I Have it the Midi Setup but Cant get it to record in protools. I have it on my input list and have the track in record just cant get it to receive the midi data. I have tried it both on Midi Tracks and Instrument Tracks. Any Ideas? Thanks!
Old 11-15-2006, 09:52 PM
Default Re: OSX Midi Controller Not Seen on Input
Are you using the MIDI I/O on the Mbox 2? Cable routing, Motif Out to Mbox In and Motif In to Mbox Out? What about Mac's Audio MIDI Setup? Is this setup?
filosofem
Aaron Mulqueen - 001 HD Native
Old 11-15-2006, 10:04 PM
I am not using any Midi Cables to connect to the Mbox 2. I pluged straight from the Motifs Usb out to the Mini. the Audio Midi Setup Recognizes it and automatically patched it in and out of the Mbox... Do I need to just get standard MIDI Cables and hook it up that way through the Mbox instead of using the Motifs built in USB Midi Interface? I had luck on the PC Side of things doing it throught the USB. Thanks for any help
Darren
Old 11-15-2006, 10:12 PM
Are you able to play a Virtual Instrument like Expand with the Motif 6? Lets say, via an Instrument track?
filosofem
Old 11-15-2006, 10:16 PM
Nope... I get no input.
Old 11-15-2006, 10:21 PM
Is MIDI Thru checked?
filosofem
Old 11-15-2006, 10:34 PM
Default Re: OSX Midi Controller Not Seen on Input *DELETED*
Post deleted by Average_Joe
On my Keybord or in mac. where do i check on the mac? I Have the USB Midi Port Active on the Keys as well as assigned to trasfer through port 1. i Appricate all the help!
Old 11-15-2006, 10:37 PM
Pro Tools Menus>Options>MIDI Thru.
filosofem
Old 11-15-2006, 10:41 PM
it was not checked but it is still not a go...
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
tap tempo input from midi controller? rpm1nj MIDI 1 09-20-2009 07:33 PM
tap tempo input from midi controller? rpm1nj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-19-2008 11:20 AM
New to MIDI. Input is quantizing. Input Quantize is disabled LiamSlack MIDI 0 03-25-2008 08:59 PM
USB input versus actual MIDI input seanhupe MIDI 3 12-23-2005 07:35 AM
