  #31
Old 09-06-2024, 03:38 AM
BarneyBarry BarneyBarry is offline
Default Re: Pro Tools 2024.9 Thoughts
Originally Posted by TNM View Post
PLEASE, never change the UI.
The UI is the Reason I MOVED to Pro Tools, as it's the best DAW GUI in the world without peer. It's the only DAW apart from Logic that never looks cluttered nor ever hurts my eyes.
And now with the custom coloring of most of the GUI - it's peerless IMO.
Just want to put a balancing opinion out there.
maybe it's not about changing UI, but changing internal code related to UI? pt have been developed for 30 years, i can't imagine technical dept
  #32
Old 09-06-2024, 09:24 AM
moogboy100 moogboy100 is offline
Originally Posted by Electronic1982 View Post
It's impossible,
Without Bug PT-263050 being fixed, it's not possible,
with all the routing going on in big Pro Tools sessions, it's important to know where each signal is going,
if I can't update the software, I can't update the hardware neither,
if this means the end of Pro Tools for me, then I'll end up stuck here forever
Well one of the many many new awesome features you've been missing out on is the Color Coding IO, which can easily solve a lot of the what's routed to where questions.
Aside from that, it's so dead simple to create a quick Memory snapshot of your current track view settings, to get back to they way you had it after using that Show Assignments thingy, I can't believe you're holding yourself back over that but to each their own I guess.
🖥️ Pro Tools Ultimate 2024.6 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.6 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.6.1
  #33
Old 09-07-2024, 04:11 AM
Electronic1982 Electronic1982 is offline
Thanks for the suggestion, but it doesn't solve the issue because Hidden Tracks will still jump out with the colour feature, and remembering to create memory location then updating memory locations every single time a new routing is assigned and un-assigned, over and oveer again is prone to mistakes due the amount of of times updating is required, instead of a simple, single click like it should be. Bug PT-263050 needs fixing.
  #34
Old 09-08-2024, 08:24 AM
1. The colored IO will not make hidden tracks jump out. It just means that, with a quick glance at your tracks, you can easily identify what's being routed and where.
2. Updating memory locations is not as hard as you're making it. I use soundflow. I have literally 1 button I can press on my stream deck to update the current "mix view memory location". So if I'm gonna do something that might be "destructive" to my current layout, I just hit the button, then I can do what I need to do and if I need to get back to my original view, I just recall that mem location with the keypad (. 1 .) (no, those are not ascii boobs, that's like, recall mem loc 1) Even w/o soundflow, it's still so easy to just apple-5, then ctrl-click a mem location to update it.
AVID does not think of PT-263050 as a bug, so they may never change it.
  #35
Old 09-08-2024, 06:12 PM
But I need to see hidden tracks selected that use the same routing across the entire sesssion in all time, this is why this approach won't work.
I can have 100+ routings going on, so this is approach is prone to mistakes, if one potential routing (or removal/ change of routing) is missed, it risk destrupting entire workflow, then I have to spend time trying to find what track jumped out and what track didn't. Selecting Tracks isn't supposed to work like this.
I can only have faith in Avid to fix Bug PT-263050
  #36
Old 09-09-2024, 10:09 AM
ejinbc ejinbc is offline
All
I have been coming to this forum for over 10 years now. The number one feature request has always been (paraphrasing) "no new features, please give us a bug free version". So far, not so much.
On the topic of Sketch, a minor mis-step perhaps. In it's current state Sketch has far fewer features than even the (almost) free Ableton Lite - recall we have Ableton Link. As far as using Sketch as an arrangement tool, a simple system of marker (or range) sequencing like Nuendo could be far more convenient and consistent with the Pro Tools interface. Or not.
Another Ableton note, I see on their website that they keep releasing bug fixes for the past major version of Ableton for those that have not updated. What a concept.
Cheers
ejinbc
  #37
Old 09-09-2024, 11:05 AM
Video engine only NEEDS to be ARM if Avid has inside information from Apple saying macOS 16 will drop x86 code altogether. So long as Apple is playing it safe, it is only a nice to have.
  #38
Old 09-09-2024, 12:25 PM
BScout BScout is offline
The AVE is still terrible.
Rosetta2 does not translate all instruction sets. The AVE isn't taking full advantage of GPU cores on the M processors. So necessary.
Pro Tools Ult 2024.6, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
  #39
Old 09-09-2024, 12:43 PM
I am hoping macOS 15 Sequoia would be the pinnacle for x86 (like OSX 10.5 Leopard was for PPC) and hoping macOS 16 would give us warm and fuzzy feelings remembering OSX 10.6 Snow Leopard which was PPC-free and super stable.
  #40
Old 09-09-2024, 07:01 PM
Eric Lambert's Avatar
Yes. There's no excuse for the delay of this much needed functionality. I was struggling with a video issue just today. Sloppy, old code. It's one of the few things on this machine which still uses the Rosetta crutch.
Crash/Freezing constantly in 2024.6 + 2024.3.1 athnony macOS 5 08-29-2024 09:38 AM
Pro Tools 2024.6 / HD Driver 2024.6 Now Available! tope d Technical Alerts 0 06-20-2024 01:00 PM
Pro Tools 2024.3.1 is out randomizer Pro Tools 11 04-13-2024 01:19 PM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
