  #21
Old 08-11-2021, 08:41 AM
[email protected] sleshnyc@gmail.com is offline
Default Re: Is there a way to see how I quantized a midi region?
Originally Posted by Robruce View Post
PT does not automatically recall or list those types of edits even within an open session, short of Cmnd Z "undo". If you're opposed to a possible workaround then skip the one below.
Duplicate the original performance take, lock the original.
Name the new take/version "logic groove x" or "87% swing" etc. and simply store every new variation that way. You'll at least be able to get back to those different groove approaches and tweak on those if you name them clearly. hth
yes thank you, this is a workaround, similar to what i've done. I'm surprised it can't be stored as some kind of meta data, not that I know the first thing about writing code.
  #22
Old 08-11-2021, 09:50 AM
DontLetMeDrown DontLetMeDrown is offline
Originally Posted by [email protected] View Post
No genius. I posted my response from Avid AFTER I posted here, hence the use of 'edit'. But thanks for another productive post.
How tf would anyone know the chain of events simply because you typed “edit”. Honestly, it’s clear from your responses that you’re trash. I’ll be sure not to chime in when I see you needing help again. 👌
  #23
Old 08-12-2021, 04:34 AM
Well, how would HE know the chain of events? So what was your response to the guy who thrashed me that I responded to? Did you read his post? See, that's the problem. I asked a very specific question, and it turns to this. My feeling is, either have a response to help the o.p. or just move on. it's totally fine if you don't know the answer. it's not ok to trash me, which is what the guy did.
And what you did. I'll try to sleep knowing I won't be the receiver of your wisdom.
Quantized Midi Notes not lining up with Quantized VST notes ozzlvlosis Pro Tools 11 1 11-07-2019 08:00 PM
I want to snap my midi, not have it all quantized. jayjaystevens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-2010 06:03 AM
Quantized midi out of time!? Nielsy Pro Tools TDM Systems (Mac) 4 09-03-2010 11:41 AM
Quantized MIDI notes not falling on the 1? jack9999 Pro Tools TDM Systems (Mac) 10 01-14-2008 11:09 AM
Groove-Quantized Midi Files.....? Phoenix1 MIDI 1 08-31-2006 01:28 PM
