ProTools Clear clips - Delete and Move to trash button not showing
Hi all,
I have Pro Tools 2018.4.0. I am saving as copy a session with many songs in order to have many sessions with sigle songs. Thus after copying and opening the new session I want to clear the memory of all the songs and the track regions that I don't use. When I select the regions that I want do delete from the hard drive I am using the "clear" option. A dialog appears but no "Delete" nor "Move to trash" option are shown. It only has the "remove" button and once I hit it, it doen't seem to remove the track from the hard drive keeping me the drive full of unwanted data. I tried to check on similar issues on the net but I could't find any solution nor discussion about this issue. Could somebody help me on that? Many thanks |
Re: ProTools Clear clips - Delete and Move to trash button not showing
Sounds like you're selecting clips and not the whole files. Clear out everything you don't want from the timeline and then "Select Unused" from the Clip List menu. (Shift-CMD-U on a Mac)
Of course make sure you're in your saved copy so you're not deleting the original files.
~Will |
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Thanks. The trick is to have always consolidated clips in order to properly manage audio files in the session.
It seems that by proceeding that way still it holds many data. By having a 20GB session by consolidating and removing all unused files and leaving just one song of 14 my session ended up to be of 10GB. It seems not the best way to have an optimised session anyway. Finally I had to export as files the only tracks I wanted to mix as a single song and import them in an empty session. I think pro tools should implement a better file management solution in order to have a more efficient way to shrink bigger sessions. Thanks anyway. You helped a lot. |
some clips get left behind when trying to move multiple clips together | Dullabills | Pro Tools | 1 | 10-06-2022 07:47 AM |
S6 “Clear” button on S1?? | indeloon85 | Avid S1, S3, Dock and Control App | 2 | 12-21-2021 09:03 AM |
In a rush I clicked "move to trash" when cleaning up unused clips in a session... | jaminjamesp | macOS | 1 | 10-17-2018 05:31 PM |
Clear Special - Delete All Automation | Kenny Gioia | Pro Tools TDM Systems (Mac) | 29 | 06-12-2009 06:04 AM |
Clear all clips crashes, Sometimes! | Kurtstudio | Pro Tools TDM Systems (Mac) | 0 | 04-05-2005 07:59 PM |
