Old 09-04-2001, 02:12 PM
yavuzj yavuzj is offline
Default Some ACID loops will not import into PT LE
As the subject says Some ACID loops will not import into PT LE. They will not even play in the import window. Anyreason why?
Anyone? [img]images/icons/rolleyes.gif[/img]
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 09-04-2001, 03:56 PM
Voideco's Avatar
Voideco Voideco is offline
Default Re: Some ACID loops will not import into PT LE
Sample rate/bitdepth? Too simple probly.
Are audiocodecs an issue in this? File may be read only. Just some suggestions.
Voideco
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3
OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6
Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard
Macbook Pro M1, 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey. PT 2022, UVI Falcon 2.6 + some soundbanks, Waves Platinum bundle
Old 09-04-2001, 04:01 PM
Jaleo Jaleo is offline
Yavuz,
I use Acid and have had good success with importing audio...What do you normally do to the Acid loop before you import it? Do you save it as a .wav? Do you change tempo? Maybe I can give you some advice, but I need more info...
Jaleo
Old 09-04-2001, 04:06 PM
Voideco's Avatar
Here's another one, from another thread:
PTLE uses the AES/Broadcast WAV file format which does have some additional information at the begining of the file. (quote)
Good luck,
Voideco
Old 09-04-2001, 04:23 PM
Roy Howell Roy Howell is offline
yavuzj,
Man, I'm having the same problem sometimes. Gotta be the type of file; I don't think it would be sample rate....
Roy
rh music
Old 09-04-2001, 06:01 PM
I'm still quite new to Acid(Have the 3.0). When your ARE finished with a loop, how do you make it a WAV to import into PT? I tried converting the Acid File, but my file converter( Using MMJukebox) won't recognize the .acd file to begin with. There's just nothing there.
Suggestions?
Thanks, Roy
rh music
Old 09-04-2001, 07:32 PM
da BaSsTaRd! da BaSsTaRd! is offline
there are a lot of wav file loops out there on the internet that are not 16/44 uncompressed waves using some wacky codecs. i had the same problem when i was using acid. either convert the wav's to 16/44 before importing them into acid, or bounce your acid session as 16/44 uncompressed.
peace....
i love my apple iPhone!
Old 09-04-2001, 07:52 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Roy Howell:
I'm still quite new to Acid(Have the 3.0). When your ARE finished with a loop, how do you make it a WAV to import into PT<HR></BLOCKQUOTE>
I use render as and choose to export each track as a seperate wave file. The funny thing is that some of them do work.
Yavuz AKYAZICI
Old 09-04-2001, 08:05 PM
yavuzj,
Good, because I tried 'Render' earlier, and it did NOT work on this particlular one. It must be the samples we start out with. Anybody, do we need to convert samples BEFORE we make them into ACID loops? How?
Thanks, Roy
rh music
Old 09-04-2001, 10:21 PM
pk_hat pk_hat is offline
yavuzj,
Thanks, Roy
<HR></BLOCKQUOTE>This does happen from time to time, and I tend to believe it's simply due to an invalid or corrupt file.
As for your Q:, Roy, I've never had to convert any .wav files to bring them into Acid. If it's a WAV, no matter where I got it, it usually works and stretches just like a loop from an Acid library Disc (which I gave up on, there's so much better out there).
I think the "Export/Render As" options were clearer in 2.0 than in 3.0, but you can still achieve the same results.
Also, you could consider this: Right-Click on the colored box(usually a circular arrow) left of the track, select Properties. This will bring up a new box at the bottom of your workscreen, and you can save from there as well, by clicking on the floppy disk icon and choosing a destination. I believe it only the affects the 'source loop', however.
I haven't used Acid since purchasing Reason a month ago (I know, I've mentioned it before [img]images/icons/wink.gif[/img]), so I'm not 100% on what I said. I know I'll get back to it eventually...
pk
[ September 04, 2001: Message edited by: pk_hat ]
www.myspace.com/krou
ACID WAV loops vs. Apple Loops scripguy macOS 1 05-18-2012 10:44 PM
Acid Loops and Rex Files Lyoko Pro Tools TDM Systems (Mac) 3 01-26-2007 04:26 PM
Need Help Using ACID loops in PT LE Spyda KB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-25-2007 02:44 PM
acid loops and PT LE drbones Tips & Tricks 6 03-30-2006 09:25 AM
ACID Loops??? Jake001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-12-2002 12:04 AM
