Old 01-24-2005, 03:39 PM
GoneIndie GoneIndie is offline
Default AES/EBU Bounce Offset
Hey All,
In a 192 session I was trying to save processing by bouncing tracks down. The only way that sounded right was to make a short aes/ebu db25 - db25 patch cable and bounce the tracks down that way. Is there any way to determine what the offset of the bounced tracks is?
Thanks in advance
Old 01-24-2005, 03:48 PM
Default Re: AES/EBU Bounce Offset
Bounce a single click and compare the original to the bounced track.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-24-2005, 04:57 PM
Steve MacMillan Steve MacMillan is offline
ProTools HD system w/192
main ch/pre send out thru a buss to an aux is 6 samples
main ch/pre send out thru a buss, recorded on a track is 10 samples
post send out to a buss, to an aux is 10 samples
post send out thru a buss, recorded on a track is 14 samples
main ch/pre send out thru an analog output, return thru an analog input, to an aux is 99 samples
main ch/pre send out thru an analog output, return thru an analog input, recorded on a track is 103 samples
post send to an analog output, return thru an analog input, to an aux is 103 samples
post send to an analog output, return thru an analog input, recorded on a track is 107 samples
main ch/pre send out thru the enclosed AES output, return thru enclosed AES input, to an aux is 17 samples
main ch/pre send out thru the regular AES output, return thru the regular AES input, to an aux is 20 samples
conclusion:
buss to aux is 6 samples
post send adds 4 samples
recording on a track adds 4 samples
analog loop is 99 samples
enclosed AES loop is 17 samples
regular AES loop is 20 samples
macmandigital.com
Old 01-24-2005, 05:11 PM
Yes, but if he has ADC enabled... he may have no delay.
Rail
Platinum Samples
Old 01-24-2005, 10:31 PM
minister's Avatar
minister minister is offline
and if he is doing a record for beck, he'd have odelay.
and if he were doing a record of swiss alpine singers, he'd have yodel-ay
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 01-25-2005, 06:25 PM
The sample rate of the session is 192 and I am bouncing from one track in the session to another (in the same session) going through the AES/EBU db-25 cable in dual wire mode with no SRC. If the delay is 20 samples does the length of cable matter? If the cable were 3000 ft long wouldnt the offset be longer? I know that is rediculous, but once the signal leaves the system how can you account for how long it takes to return. I dont think digi should stop until the sample rate is the speed of light. The HDc system would really capture the high end I bet.
Offline bounce offset Peter Baird Pro Tools 11 5 01-15-2014 02:19 PM
Video Sync Offset/Bounce question efisch Post - Surround - Video 2 02-18-2009 11:42 AM
aes/ebu bounce offset GoneIndie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2005 01:09 PM
DIGI! Midi Offset and bounce to disk? Problems! P_J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-01-2001 11:33 AM
DC Offset during bounce psjosten Pro Tools TDM Systems (Mac) 5 10-28-1999 02:12 AM
