#821
Re: New "Mac Studio" from Apple
Hoping to bring some data to the party:
Starting with Pro Tools 2022.5 (in Rosetta on the Ultra) 96khz Atmos session - 338 voices - immersive reverbs - lots of automation - 2048 sample buffer - Dolby Atmos Production Suite: •On my old Mac Pro 6-core 6,1, this session couldn't make a DAMF master until I froze all the reverbs, half the plug-ins, and turned off headphone and re-render processing. Then, if I whispered magical incantations and didn't touch the machine, it could record a DAMF master. Then I took the session as it was and did the same thing on a Mac Studio Ultra, full spec. Looking at Activity Monitor: Mac Pro 6-core 6,1 64GB RAM: Pro Tools CPU = 623.6% DAPS = 90.6% User = 62% Idle = 27% Mac Studio Ultra 20-core 128GB RAM: Pro Tools CPU = 353.9% DAPS = 77.5% User = 25% Idle = 69% •Then, I unfroze everything in the session, turned binaural and re-render processing back on and went back to Activity Monitor: Mac Studio Ultra 20-core 128GB RAM: Pro Tools CPU = 585.0% DAPS = 125.2% User = 39% Idle = 54% So what does this mean? Geekbench multi-core lists: Mac Pro at 4,557 Mac Studio Ultra at 23,370 But if we hold that number from the Mac Pro steady at 4,557, and extrapolate from my unscientific test above, the Mac Studio Ultra is actually 11,300 (maybe Michael Carnes can check my math! ) And keep in mind that this is Pro Tools in Rosetta mode. (2825 is 62% of 4557 and 2825 is 25% of 11,300)
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn Last edited by reichman; 06-26-2022 at 07:58 AM. Reason: grammar |
#822
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... |
#823
I've run into an edge case where I can hear the fans. Do I win something?
I'm using iZotope RX to do some offline cleanup (I'm restoring a number of old cassettes--pity me). Currently it's spectral noise removal and de-crackle that push it. RX is pretty good at loading up every single processor core to get a job finished quickly. Activity Monitor shows all cores at maximum. The fan comes on soon after the job pegs Activity Monitor. and goes off about a minute after the process has completed. It's not bad--a little under 50dBA at about a meter--but it's still pretty noticeable. I still haven't heard the fan in a mixing or editing situation (and I work at very low levels). I'll point out a couple of things: my now-departed 2019 Mac Pro sounded like a 737 on the runway in the same situation. And this is the MacBook Pro Max. The Mac Studio has what's claimed to be a better thermal system and fan. So I'll be very interested in hearing what people experience with it in similar situations. I suspect this sort of work (VIs aren't the only thing I use) that will really take advantage of an Ultra. While it might not be twice as fast, it will be darned close. |
#824
Really? I was under the impression that those machines stayed quiet no matter what.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
#825
PS - I should add that there were 3 full-sized PCI cards in the box for M.2 and SSDs. No HDX. |
#826
#827
Not that it matters, but two separate threads were started and the mods combined them into this one. And not that it matters, but my thread asked questions and began the queries whereas the other - yes, 8 minutes earlier, not that it matters -- was simply the announcement. Not that it matters.
#828
The Studio Ultra has finally been moved into the studio after several days of installation and configuration and it's running incredibly well. I can't remember having so few hiccups relative to so the amount of work involved and I've been setting up computers since '84. Brilliant machine.
It absolutely screams! Restarts, PT starts, plugin loading, edit window navigation, bouncing, etc. Yes, everything. And CPU loads have remained low though I have yet to do any kind of scientific test (because at this point I don't care -- it's handling my largest sessions with a breeze). This was a complete fresh installation. I don't know that I could possible have been more diligent with each step, ensuring that everything is honed and operating properly without excess. Nearly every installer came fresh from the developer so that the latest/greatest was always used. The only thing that migrated from the old machine was the sample drive which contains all samples. This made life easier. And iLok was a savior here. The biggest hassles came in dealing with authorization codes and contacting tech support to get them sussed out. This was done while producing an active gig, I simply installed the necessary elements to get that session open, so I could work, then I continued with the rest as time permitted. I'll be back with more info as time permits. All in all, I couldn't be happier. |
#829
I'll send you a Snickers bar because you are indeed a winner. I've not heard a sound from this thing in 5 days. I very faintly hear my TimeMachine drive (a platter drive) but that's it.
#830
Good news, thanks Eric.. My one room set up definitely benefits from as little computer noise as possible .
Complete Recording Studio FOR SALE! Pro Toold Hd2 Accel, C24, Apple, Mogami, etc... | sketchellis | Buy & Sell | 15 | 05-06-2013 06:27 PM |
apple-m "mute region" clash with finder apple-m "minimize" | wez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-12-2007 05:19 AM |
2 Power-Mac's on 1 Apple Studio Display? | Optimus Prime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2004 01:11 PM |
Has anyone had this problem with their Apple Studio Display? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-29-2002 12:55 AM |
Please advise on best setting on Apple Studio Display LCD Flatscreens - going blind! | Jules | Pro Tools TDM Systems (Mac) | 5 | 05-05-2001 12:54 AM |
