Old 03-09-2017, 12:40 PM
TrentWilliams TrentWilliams is offline
Default HW Device at a Different Sample Rate
Hello,
When i'm using iZotope's RX through RX connect, I get a notification with Pro Tools citing 'The HW device is at a different sample rate from the open session'.
Now I know what this means, but when I go to change the sample rate of RX I can't see any option? Is there a way to sync the two applications?
Any help is appreciated.
- T
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 04-29-2024, 05:30 AM
schoen schoen is offline
Default Re: HW Device at a Different Sample Rate
update from izotope:
Sample Rate Issues with the RX 10.4.1 and RX 10.4.2 Audio Editor
Symptom
When opening the RX 10.4.1 / 10.4.2 Audio Editor, the audio interface's sample rate changes to 44.1 kHz. This can cause audio artifacts and performance issues with the stand-alone application.
Solution
The issue has been fixed with RX 10.5. Please open Product Portal and install the latest RX update.
Old 04-29-2024, 07:15 AM
smurfyou smurfyou is offline
Yes it's a really annoying bug I've only had with v10.
Thank you, I didn't know they fixed it.
~Will
Win 10 playback device does not support sample rate tmaca Windows 5 12-18-2016 07:17 PM
HW device is different sample rate AVID john1192 macOS 3 10-15-2013 11:41 AM
Pro tools could not set your audio device to the correct sample rate innermusic Pro Tools 10 4 05-06-2012 09:25 PM
Mytek + The HW device is at a different sample rate from the open session glynnp macOS 2 10-20-2011 03:53 PM
HW device is at a different sample rate from the open session bad jitter Pro Tools 9 2 08-16-2011 11:36 AM
