BUG REPORT -- WinXP, DVerb, and 9128 error.
Hi All,
This has probably been reported to death, but I'll throw my 2 cents in... Ever since I upgraded to WinXP and ProTools LE 5.3, I get a 9128 error whenever I use the DVerb setting where the "Room 2" algorithm is checked along with the "small" size setting. If that setting is used even once in a session, ProTools will pop a 9128 error. CPU usage will bubble along during playback and then suddenly spike, causing the error. If I change the DVerb setting to ANYTHING else, I don't get the error. I spent $650 on an upgrade (from PIII 1 GHz, Intel MoBo, 815 chipset, 512 MB RAM....to a P4 2.4 GHz, GigaByte Mobo, 845EP chipset, 512 mb RAM) troubleshooting this bug. Even with a state o' the art PC with half a gig of RAM, CPU usage would still spike. DIGI, are you aware of this? Is a patch in the works???? Enquiring minds want to know........ [img]images/icons/confused.gif[/img] xoxoxoxo, John |
Re: BUG REPORT -- WinXP, DVerb, and 9128 error.
I get all sorts of CPU anomalies with D-verb ever since I installed XP on my P3 750. But it really doesn't matter much to me because I don't like D-verb. Ren Verb is nicer.
What really bugs ( [img]images/icons/tongue.gif[/img] ) me is that I can't select which tracks are visable unless the session is in play mode... Weird stuff. |
APaulos,
What is ren verb and where can I get it? John |
Yeh, the RVerb is way nicer than Dverb. I know they say that it's good to have different flavors to create with, but ever since I got Rverb I haven't been able to use Dverb. Not just cuz the bugs. There's something about the sound that just doesn't sit well with me.
You can get the Ren Col for about $250 and you'll have a much improved reverb, a great compressor, and a very nice EQ. That's action! The presets on Rverb are allright but they're a little dark for my taste. You can adjust every parameter of this thing, which is another big plus. So until Altiverb is available for PTLE, this is the one.
7psalms.com |
This is a real bummer for me - I love some of the D-verb settings on drums - not for verb (Have outboard TC and Ren for that) really to add color and dimension to snare drums. Hope they Iron this one out....
ya know, it's funny, I quit using R-Verb 'cause every time I tried to use it I got the 'running out of CPU' error. I also get this with the C4 in the 'Multi Electro Master' setting (or whatever it is).
What's the deal? I have a 2.26GHz Pentium 4 running XP. Isn't that enough? [img]images/icons/shocked.gif[/img] |
me too.....I contacted digidesign months and months ago and they told me "we're working on it" and that It wasn't just a problem with dverb that it was actually all of their plugins....that they hadn't been optimized for xp yet. That's something to think about before you release a product for xp. Matt...I agree about the drum stuff..I used to use dverb on drums as well. The Rverb is great, but it seems to be a system hog as well.
How many A&R guys does it take to change a light bulb??? I don't know. What do you think? |
DAE ERROR 720/ also error (-9128):advice needed | GeorgieC | macOS | 0 | 08-14-2012 03:32 AM |
error -9128 | Blackers | Pro Tools 10 | 1 | 12-26-2011 06:45 PM |
DAE error -9128 | rtm | Pro Tools TDM Systems (Win) | 0 | 10-26-2009 03:33 PM |
error -9092 & error -9128 problems | zippitydoodah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-25-2007 08:04 AM |
error -9128??? | jlr929 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-20-2006 10:30 PM |
