Help needed for new Pro Tools set-up
I am a 30 year voiceover studio guy looking to move from a G4 (os9 with Lynx PCI card)
to intel Imac as my main studio cpu. I've mainly used 2-track apps like bias peak and standalone daw's in the past but want to run pro tools as my main application on the newer mac. Primarily the work done is simple mono voice tracking and occasional fully-mixed radio spots and tv audio which require - typically no more than 8 channels. (and as absolutely simple, pared-down screen display as possible...no midi, no music needs, this is broadcast production-based usage alone... i would love an interface that rivals the long-ago simplicity of original "Session 8" or something rivaling Peak 2.6 with 8 channels -- but that's obviously too simple for today's standards and another topic). Anyway...my audio input is never more than 2 channels at a time. Got a few questions that are holding up a buying decision re: PT. First, for the kind of stuff i'm doing, are mbox converters good enough for pro broadcast applications (I would be using my higher-end preamps - not those of the mbox). Also, given my particular application, is there any major reason not to just go with a current or previous generation USB mbox vs a firewire (Pro or 002 ) one...If USB, how much is latency really a factor and does the pt USB box give you some form of zero- latency monitoring feature? Is it fairly straightforward and glitch-free to use non-Digi software like Bias Peak with Digi Hardware or is that cumbersome to configure and expect to be 'rock solid.' ? I would assume with the right drivers it should be okay but i try not to assume anything... Finally, would there be any issues/problems running PTLE with, say a prior generation usb mbox in the latest OSX Tiger OS? (I am at 10.4.10 and will probably stay there for a while on the G5). Thanks in advance for any thoughts or advice. Mike
Voiceovers For All Media...Since 1970-something... |
Pro Tools 11 Help needed | sam.adler97 | Pro Tools 11 | 7 | 11-01-2013 11:31 AM |
Pro Tools SE needed | manansinghi | Pro Tools SE and Essential (Mac) | 1 | 08-22-2012 10:19 AM |
Help needed with Pro tools | boycie | Pro Tools M-Powered (Win) | 0 | 05-05-2011 03:32 AM |
Pro Tools 8 LE help needed! | Mr Jay West | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-12-2009 05:48 PM |
Pro Tools 8 help needed. | Mr Jay West | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-12-2009 12:05 PM |
