MTRX Studio with Dante DVS: Cannot Change Sample Rate
I recently purchased a MTRX Studio to use with Dante DVS and Reaper in our new Atmos mixing suite. Within the first 48 hours I had great success getting things up and running in DADman, DVS and Dante Controller.
One problem that I simply cannot resolve on my own is that if I change the sample rate to anything other than 48 kHz in the Configuration panel of DADman and in the Device View in Dante Controller, Dante shows an error on all channels and all audio playback ceases. When I check Reaper's Audio Device Settings it shows a sample rate of 48 kHz regardless of what is actually set in DADman and Dante Controller. Similarly, when I check my MacOS Audio MIDI Setup, it shows a sample rate of 48 kHz with no option to change it, regardless of the actual sample rate set. I'm pretty sure that I've tried every setting combination in the Config dialog of DADman and the Device View of Dante Controller, with no success. I've attached images of my current settings, for reference. Any suggestions would be much appreciated! |
Re: MTRX Studio with Dante DVS: Cannot Change Sample Rate
DVS has to be manually changed for sample rate.
It does NOT follow clock. That's your issue. If you would like to change the sample rate of DVS you have to do it from Dante Controller software (You select the DVS device and then go in and change sample rate.) This is a decision Audinate made for DVS (probably to convince people to buy hardware with their chip.) Once you change DVS's sample rate, since you've decided to clock the MTRX internally, you have to change that clock to the same sample rate. In Dante Controller, the MTRX should also be set to be the primary/master clock as a preference.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks BScout! I actually resolved the issue on my own shortly after posting this. It turns out that I was setting the sample rate correctly in the DADman software and in the Dante Controller Device view for the MTRX Studio, but I missed that you also need to set it in a third location: the Dante Controller Device view for the DVS (i.e. the DVS Core Audio Driver). Once I set the same sample rate in all three places, everything worked as expected. Definitely a little confusing, but I can live with it.
The sample rate changing could be better on this system. It freaks people out when they can still see deflection (meters) after changing a sample rate, but can't hear audio. The Dante Controller software is a bit messy for the non-initiated engineers using my place. Too many panicked phone calls for my liking.
Mac Pro Rack - Ventura PT 23.12 HDX - MTRX Studio Mac M2 13" Air in the field |
Sample rate of DVS always needs to be changed separately.
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
Thanks Jan - I appreciate the screen shots. This will definitely save me a step. I've only had the interface for two weeks, but I am really enjoying the power and flexibility of it so far.
MTRX Studio with Dante DVS: Cannot Change Sample Rate | andrewyankiwski | Pro Tools | MTRX & MTRX Studio | 0 | 01-02-2023 02:58 PM |
MTRX Studio and Dante DVS - Problem Changing Sample Rate | andrewyankiwski | Pro Tools | MTRX & MTRX Studio | 0 | 01-02-2023 02:34 PM |
MTRX Studio automatic sample rate switching issue | AINSLIE | Pro Tools | MTRX & MTRX Studio | 5 | 09-03-2022 02:29 AM |
Dante SRC on MTRX Studio | ViciousLullabyz | Pro Tools | MTRX & MTRX Studio | 4 | 02-04-2022 03:00 PM |
DADman/MTRX Studio sample rate, Avid Control monitoring issues | raw | Pro Tools | MTRX & MTRX Studio | 8 | 01-24-2022 08:09 PM |
