Old 04-27-2003, 10:36 AM
Klepto Klepto is offline
Default Heat problem
Has anyone had a problem with their HD cards over heating? I have an HD3 system in a new G4 tower and everthing works great for about a half an hour, but after that i get an error message and try to reopen PT and u get a flex cable error. When i open to check theres a lot of heat coming off the processors(oh yeah the flex cables are hooked up right), when i let it cool down for a couble of hours PT will work for a half hour, the "over heat" again.
If anyone has had this problem, what did you do to solve it?
Old 04-28-2003, 10:27 AM
lagasus lagasus is offline
Default Re: Heat problem
Sorry I do not have a solution for you, but I have heard that in order to make the new G4s quieter than the previous Mirrored Drive Door models, Apple put a less powerful fan in. This would explain the extra, and from the sound of it, potentially unsafe heat.
Old 04-28-2003, 10:57 AM
andrej770 andrej770 is offline
I concur. I would complain to Apple and find out more about their Power Supply/FAN replacement program. They currently have one for faulty ones, maybe they will replace yours too.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
Old 04-28-2003, 03:29 PM
Lee Blaske Lee Blaske is offline
What's the temperature of the room where this equipment is located? It's not in an iso box, is it?
Lee Blaske
Old 04-28-2003, 04:50 PM
It's in an AC ed control room, around 65.
Old 04-29-2003, 03:14 AM
Borivoj Borivoj is offline
More info about exchange is on
https://depot.info.apple.com/generic/index.html
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Heat johnnyz Pro Tools HDX & HD Native Systems (Mac) 4 04-28-2012 11:45 AM
Heat vrs VCC vrs NLS Howardk macOS 11 04-14-2012 08:19 AM
APPARENT HEAT RELATED PROBLEM IN G4 DUAL 500 sbarncar Pro Tools TDM Systems (Mac) 3 06-10-2004 04:08 PM
Nanosyncs = heat problem? Borgbilly Pro Tools TDM Systems (Mac) 0 08-01-2001 03:28 PM
