Old 02-15-2011, 06:23 PM
djmichael.london djmichael.london is offline
Default Trouble upgrading help
I have been using PT 7.4.2 on a macbook with osx 10.5.8. I just bought an Imac running osx 10.6.6. I put 7.3 pt install disc that came with my Mbox mini also did the upgrade to 7.3.1 the went to mydigi accnt and got my download of 7.4 and 7.4.2. However in my accnt it only shows auth code for 7.4, Where is the auth code for 7.4.2 & is it going to work because all the compatibility charts say I need PT 8? And if that is the case why do versions 7.3.1 work just fine on osx 10.6.6 snow lep...
MichaeLondon
Mac : IMac 3.0 ghz/OSX 10.6.8/Mbox Mini/PT 7.4.2
DAW : Pro Tools 7.4.2 - Mbox Mini
www.myspace.com/michaelondon
Old 02-15-2011, 07:56 PM
nst7 nst7 is offline
Default Re: Trouble upgrading help
Protools 7.3.1 and 7.4 are not compatible with Snow Leopard. You will need to at least be on PT8, and at this point you might as well upgrade to PT9.
Old 02-15-2011, 09:09 PM
7.4 is working just fine right now on snow leopard.
MichaeLondon
Old 02-16-2011, 04:11 PM
never mind I got it... the auth for 7.4.2 was the same auth for 7.4..
7.4.2 works just fine in Snow Leopard
MichaeLondon
trouble upgrading 9 to 10 on new mac n8mee macOS 3 11-07-2011 08:32 AM
Hi. Has anyone had trouble getting Reason 4 to recognize the 003 Rack after upgrading zbeats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 05-12-2010 04:19 PM
Trouble upgrading from 7.0 to 7.4 Chuck1073 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-01-2010 09:49 AM
Trouble upgrading to LE 8 decayd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-16-2009 09:18 PM
Trouble upgrading to XP gleiter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-11-2005 10:19 AM
