Move MIDI note to Cursor
Hey all!
Is there a way to make a MIDI note snap to the cursor location with a click/key command? For example, with an audio clip I can put the cursor somewhere and CTRL-click and the audio clip will snap to the cursor location. I use this all the time. Is there a MIDI equivalent? Usage example: I have a drum loop and I'm layering MIDI under it. I record some MIDI and want to line it up with the loop. Ideally I'd tab to transient on the audio and then with the MIDI track in 'notes' on EDIT view hit a key/click combo and my MIDI note would move to where the cursor was. Does that make sense? Seems like a easy/cool thing to do and it'd be great if this worked somehow. Thank guys! Mike |
Re: Move MIDI note to Cursor
1. Make sure the Grabber tool is selected, or the Smart Tool. 2. Hover the Hand icon over the MIDI note. 3. Hold down the control key - the hand icon will change. 4. Left click the note. The note will move to the cursor. This won't work if the Grabber Tool is set to Separation (scissors). Command-Control-click will move the right edge of the note to the cursor. WINDOWS I think the commands are Start-click and Control-Start-click
Pro Tools 2023.9 Ventura 13.6 |
Glad you got it working.
Instrument track only plays back the MIDI note my cursor is over when I hit play | ducmad | Pro Tools | 3 | 08-22-2021 09:11 AM |
Move edit cursor to play cursor | EneMeneGratschik | Pro Tools 12 | 2 | 04-03-2017 01:48 AM |
C24 - Can't move cursor | don4777 | ICON & C|24 | 5 | 03-06-2014 04:48 PM |
Loop selection disappears when open midi part and move a note for example. | headsup | macOS | 4 | 12-13-2011 12:15 PM |
um, How do I move the cursor? | will the moor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-10-2005 01:41 PM |
