Old 12-14-2004, 04:35 PM
STUDIO 44 STUDIO 44 is offline
Default \"F\" Keys
Small Catastrophe...Need to re-assign my "F" keys for 'shuffle'/'slip'/'grid' etc. Can't find how to do it. Can you help?
Thanks,
Ron
Old 12-14-2004, 04:59 PM
Mt.Everest Mt.Everest is offline
Default Re: \"F\" Keys
Not enough info to be sure, but Im guessing you have either changed kybd shortcuts in the "Keyboard & Mouse" prefs, or have set different functions in " Expose " for the F Keys , also in the system prefs application.
Tool around in those two Apple prefs panes to see if you find it..
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 12-14-2004, 06:11 PM
FYI,
I originally got in trouble by throwing away "LIMEWIRE" preferences (their fix), so I could connect to their network. Bunches of unrelated stuff went away. Thanks for your suggestion. Nothing yet.
Ron
Old 12-14-2004, 06:58 PM
Are you sure the F Keys arent being taken over by Expose? And also, are you running osx 10.3 ?
MT
Old 12-15-2004, 05:44 PM
HARK! The solution: When I went to KEYBOARD from the Control Panel and tapped the FUNCTON KEYS button and the Hot Function Keys window came up, I had to UNCHECK 'ENABLE HOT FUNCTION KEYS'. Now, everything is back to normal with all the "F" keys activating Shuttle/Slip/Grid etc.
Thanks for your time. By the way, I'm running OS 9.2
Ron
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 10:49 AM
EZ Keys is OUT! Kris75 AAX Plug-ins 7 07-05-2013 04:01 PM
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 09:15 PM
Quick-keys..& X-keys Ru_C Pro Tools TDM Systems (Mac) 10 10-24-2006 11:13 AM
function keys don't work as quick keys miked45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2003 10:32 AM
