TL Master Meter Not Working
PT 10.0.1
Digi 003 The TL Master Meter plugin doesn't appear to be working on my desktop 003 system; I upgraded my desktop and my laptop to PT 10.0.1 at the same time, and the plugin IS working on the laptop... any ideas what to try, to get it working? |
Re: TL Master Meter Not Working
Did you ever figure this out?
TL Master Meter worked on both my PT9 and PT10 systems initially, then mysteriously stopped working. It will display the TL Master Meter window but the meters do not work and there is textual garbage where the numeric values are displayed. The only thing I can think of that I did about the time it stopped working was adding an m-Audio Axiom Pro 61 midi controller to both systems. I'm thinking the driver may have overwritten a DLL (dynamic link library) that TL Master Meter uses. But that's just a wild guess. I really have no idea why it stopped working and continues to not work. So, did you find the problem? Thanks! |
Just a quick update for anyone else having this problem...
For me it was the m-audio Axiom Pro driver (version 6.0.3: AxiomPro_Installer_6_0_3_Driver_5_10_0_5134.exe). When I unistalled the driver, the TL Mastermeter began working normally again. Downloaded the driver again paying close attention to operating system, service pack and 64 vs 32 bits. Reinstalled and things are working now. My guess is that I downloaded the wrong driver for my operating system the first time, although it's difficult to know at this point because the file name appears to be the same no matter what version of the driver you download. So if anyone else experiences this issue, this is at least one place to look. |
Ok, one last comment just for the record...
The driver I downloaded was correct. The problem occurs when I configure the Axiom Pro 65 for use within Protools in the setup peripherals dialog. When the keyboard is configured for use, the TL Mastermeter stops working. Deconfiguring the keyboard in the dialog allows the TL Mastermeter to start working again. On/off, on/off, as predictable as death and taxes. So the workaround is, if I want to use the TL Mastermeter, I have to deconfigure the Axiom Pro. You'd think a company that made both the hardware and the software could find a way to make them both work together wouldn't you!? Well, apparently not! (And I won't even go into the issues I've had with my mbox pro subsequent to a firmware upgrade.) For a company that supposedly defines the industry standard in audio, Avid certainly seems to have some serious quality control issues! I certainly did not expected these kinds of QC problems when I chose Protools. |
Master meter? | Tyderian | Pro Tools 9 | 1 | 04-04-2012 01:07 PM |
master control room meter? | Arkadi | Pro Tools 9 | 0 | 12-02-2010 01:25 PM |
5.1 master, meter is LCR only? (PT's8) | TCDet | Post - Surround - Video | 0 | 05-27-2009 08:04 PM |
Master Meter clips | Siegfried Meier | Pro Tools TDM Systems (Mac) | 7 | 05-29-2008 07:02 AM |
