I've read all the threads I could find about this problem and have implemented many of the solutions that worked for them, but I continue to have the issue. I receive sporadic white noise/static noise during playback. I can often save the session, exit, and reopen PT and the session and it will be static free for sometimes an hour. But I can not count on this as sometimes it will only last a minute before the white noise returns.
I have disabled 1 of the Delta 44 PCI cards, and only have the OS, Sisoftware, QuickTime, and PT 8.0.3 M-Powered installed on the C drive. I read and implemented the optimization settings for Windows I found on this thread: http://www.protoolsusers.org/index.p...&catid=3#13302 I appreciate any help you can provide me here. The sandra is listed below: SiSoftware Sandra Computer Model : Dell OptiPlex GX280 Workgroup : Host Name : User : Processor Model : Intel(R) Pentium(R) 4 CPU 2.80GHz Speed : 2.8GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Integrated Data Cache : 2x 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 lines per sector L2 On-board Cache : 2x 1MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : Dell 0U4100 BIOS : Dell A03 09/17/2004 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 Chipset Model : Dell 82915G/GV/GL/P/PL/GL/910GE/GL Grantsdale Host Bridge/DRAM Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 2GB DIMM DDR2 Shared Memory : 8MB Memory Bus Speed : 2x 267MHz (534MHz) Memory Module(s) Memory Module : Super Talent SUPERTALENT02 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Super Talent SUPERTALENT02 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Video System Video Adapter : Intel(R) 82915G/GV/910GL Express Chipset Family (8 SP 333MHz, 128MB DDR2, Integrated Graphics) Storage Devices Seagate ST340014AS (40GB, SATA150, 3.5", NCQ, 2MB Cache) : 37GB (C:) WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", NCQ, 32MB Cache) : 466GB (D:) (E:) (G:) SAMSUNG CDRW/DVD SM-352F (ATAPI, DVD+-R, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices Hard Disk (C:) : 37GB (NTFS) @ Seagate ST340014AS (40GB, SATA150, 3.5", NCQ, 2MB Cache) Hard Disk (D:) : 195GB (NTFS) @ WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", NCQ, 32MB Cache) Hard Disk (E:) : 129GB (NTFS) @ WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", NCQ, 32MB Cache) Hard Disk (G:) : 142GB (NTFS) @ WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", NCQ, 32MB Cache) Optical Drive (F:) : N/A @ SAMSUNG CDRW/DVD SM-352F (ATAPI, DVD+-R, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Intel 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge LPC Legacy Controller 1 : SMSC LPC47M584-NC Audio Device : VIA M Audio Delta-44 Audio Device : VIA M Audio Delta-44 Audio Codec : Gammagraphx 0000h Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Dell 82801FB (ICH6) Ultra ATA Storage Controller Disk Controller : Dell Optiplex GX280 USB Controller 1 : Dell Optiplex GX280 USB Controller 2 : Dell Optiplex GX280 USB Controller 3 : Dell Optiplex GX280 USB Controller 4 : Dell Optiplex GX280 USB Controller 5 : Dell Optiplex GX280 SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
Just a thought.... I had a particular session I was trying to record and I'd get clicks and hisses galore.. Frustrated.. I like to bus all tracks to, what I call a Monitor Aux track, and then bus that to another Mixdown Audio track..that I'll record to for Bounces etc. Well, I decided to delete the Mixdown audio track and all it's playlists and then create a new Mixdown Track.. That did it for me.. no more clicks and hisses. Now why it worked, I haven't a clue, but maybe if you record in the same sort of manner, maybe there's a mixdown track for you to delete..... Regards.
I appreciate the reply. There are no mixdown files for me to delete. I get the white noise/static even if I create a new session and import an mp3. I have tried deleting my session and starting over, but the sporadic static occurs regardless of what track or tracks I create or import.
I'm really at a loss for the cause here. I've got the system down to nothing except the OS, Quicktime, Sisoftware, and ProTools M-Powered 8.0.3. I've brought up task manager and can see that the processor and memory are not being taxed heavily during playback. |
I'm having exactly the same problem.
PT M-Powered 8.0.3 Windows XP SP3, 32 bit. M-Audio Fast Track Ultra 8R Here's a soundclip of the kind of noise I'm getting (ignore the track, it's a jingle my friend had to write for uni- the main burst of noise is halfway through the track) http://soundcloud.com/username/axels-jingle-bounce-1 If I restart Pro Tools, I might get one or two noise free playbacks, but then every subsequent playback will at a burst of noise. Any ideas? |
Wait, that link don't work!
Try this one- http://soundcloud.com/rhyscatlin/axels-jingle-bounce-1 |
I had terrible White Noise Problems on 8.0.3 when ever I tried to do a Punch In, but PT 8.0.4 corrected all of my White Noise Problems.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Your white noise on the clip you linked is the same as what I experience.
I've noticed several forum threads on this white noise problem. I could not find a common item to them. The resolution for the ones lucky enough to have resolved it were all different. I've been chasing this problem for 6 weeks now and have posted on another forum as well. I would hate to throw good money after bad on an upgrade to 8.0.4. I will check on it though. Protools is unusable to me in this condition. |
8.0.4 is a FREE Upgrade from 8.0.3... Plus 8.0.4 is way more stable than 8.0.3... I would go to the AVID web site and download the FREE Upgrade. I felt the same way as you my Pro Tools was completly unusable for me with The White Noise problem and for a long time I realy felt like no one cared. http://avid.custkb.com/avid/app/self...p?DocId=364971
I know this sounds simple and maybe obnoxious, but consider just going to Win 7.
I had the same problems you describe, tried everything, and in the end, it seems (to me) that XP just doesn't support PT entirely. With all the attempted tweaking over 18 months in my musical (not so) fun-zone, trying to deal with random (impossible to properly troubleshoot) distortion, I could have learned 100 guitar chords. Try it if you can, get back to music, and pass on the word. |
Yep, upgraded to 8.0.4 and everything's sweet. Thanks.
static white noise | Rawer | macOS | 15 | 03-31-2013 01:16 PM |
Audio Track Playback Static/White Noise Issue | c1rcac1rca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-30-2012 10:09 PM |
Static noise (aka White noise ) During playback. =/ | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-23-2010 04:06 PM |
White Noise/Static during playback w/Mbox & PT 6.4 | Josh Greenberg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-05-2004 05:48 PM |
LE 6.2.3 Static Or White Noise During Playback!! | Sicks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 05-15-2004 07:49 AM |
