Old 04-30-2005, 10:27 AM
Superclock Superclock is offline
Default Linking faders
I have a Central Station as well as a dedicated headphone amp. I send a different cue mix to each one by assigning tracks to hardware outputs via the aux sends. It is a huge pain in the ass to set up each cue mix. They are often times very similar to the main mix, with maybe the vocal boosted, or the click track boosted, etc. Is there a way to link the aux/bus faders with the main faders so that they mirror the main faders? That way I could start out each cue mix with the main mix and then unlink and make ajdustments after that.
Old 04-30-2005, 10:58 AM
mrufino1 mrufino1 is offline
Default Re: Linking faders
If the auxes are all post fader and set to default to 0, then if you adjust the main faders these will follow suit, then you can fine tune to taste. If not default to 0 (set to default to -inf) you would have to do each one individually.
Old 04-30-2005, 11:07 AM
The only problem with that is if I want to make main mix adjustments during tracking the performer will hear the changes in the headphones. What does the "Send Level Follows Groups" function do?
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 09:11 AM
linking midi controller knobs/faders to protools?? bms51387 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-25-2010 03:29 AM
Linking faders rivetheadsound VENUE Live Sound Systems 2 11-06-2009 05:28 AM
Linking faders? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-06-2008 01:19 PM
Recording setup and linking faders mecks VENUE Live Sound Systems 1 10-11-2007 01:21 PM
