Old 08-27-2000, 06:32 PM
aggybass aggybass is offline
Default Digi001 vs Cubase
Hi, I'm thinking of buying Digi 001 and would
really apreciate some advice/insight.I have a few questions:
1) How does digi stack up against Cubase VST?
(I have cubase 3.5 which I don't own so
I have no support or way to upgrade)
2) Will digi be compatible with a G4 with OS9?
3) How do I get the midi interface on digi to
hook up to the G4.USB adapter?
Many thanks to all who reply.
Aggy
Old 08-28-2000, 09:48 AM
lwilliam lwilliam is offline
Default Re: Digi001 vs Cubase
These topics have been covered, but not in a while...
1. Cubase vs PTLE: Cubase is a better sequencer at the moment; PTLE is a better audio editor and mixdown DAW. I use both. Choose your poison...
2. Digi IS compatible with G4s and OS9. It's what I'm running (OS 9.0.4). I believe it's even compatible with the dual G4s just coming out.
3. The midi interface on the 001 is built-in and gets connected when you connect the main interface. You can use an external USB midi interface in addition to the built-in one if you want (I have a MOTU MTP A/V using USB).
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 08-28-2000, 02:13 PM
sandman sandman is offline
hey william ,dont mind to aswer small quastions ....
does your mac G4 handle both pgm ?
is this working 100% good and synced (via iac drvr) ?
cpu ?
ram ?
i like cubase (for the last 6 years) what i did was
connecting 2 computers ... mtc sync PT>>cubase .
if we are on the first steps of PT with midi >so
more work is in order !
TNX
[This message has been edited by sandman (edited August 28, 2000).]
Oh, it gives off an orange cloud of light, that just flows right out over the sea... wow!
Old 08-28-2000, 04:04 PM
I haven't tried Cubase and PTLE with the IAC driver yet. In THEORY, it should work (if you have enough RAM for both programs). If the new PTLE 5.1 doesn't have the midi features I need, I may give it a whirl, tho'.
LW
Larry
DIGI001 with Cubase CocaColey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-13-2003 07:13 PM
Digi001 and Cubase VST KaiXXX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-04-2001 07:26 AM
digi001 and cubase cloud 71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-06-2000 02:59 PM
Digi001 & Cubase VST?? discord3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-17-2000 11:23 AM
Cubase with Digi001, where to set latency on Cubase Eiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2000 08:28 AM
