Old 08-03-2007, 09:12 AM
Andres Gonzalez Andres Gonzalez is offline
Default default I/O assignments for New Track
Whenever I add a New Track--an Aux Input Track for example--the Input and Output assignments always default to those of my first Hardware interface.
For New Track, is there any way to change this default Input and Output assignments to something else? Whenever I do a New Track, I would like my default Input assignment to come up as No Input and my default Output to come up as one of my Busses not an Interface.
Thanks,
-Andres
Old 08-03-2007, 10:02 AM
Stig Eliassen's Avatar
Default Re: default I/O assignments for New Track
You can choose any bus or output path to be your default output in the I/O Setup (Output tab - New track default output).
AFAIK, you can't do the same for inputs, but you can import pre-routed tracks from a template.
Old 08-04-2007, 11:35 AM
Thanks for your response--this helps.
-Andres
Old 08-14-2007, 07:37 AM
Matthew Steel Matthew Steel is offline
In my minimal experimentation with this, it seems that the order of input paths in I/O setup is referenced when creating new tracks. Try dragging them up and down and see if it makes a difference.
Track assignments vanish on artist mix Toto2004 Artist Series 0 05-28-2013 05:52 AM
Pro Tools mixing up Instrument Track assignments? Onager1286 Windows 1 03-03-2011 11:23 AM
No track assignments to hidden tracks! zoundsabar Artist Series 0 01-10-2011 05:12 PM
Changing track input/output assignments corrupts session files, causing PT to crash. horribleheaven Pro Tools M-Powered (Win) 1 07-08-2010 11:47 AM
default track colours in PT8 polf Tips & Tricks 3 06-09-2010 03:47 AM
