C/24 loses ethernet randomly
Our C/24 keeps losing the ethernet connection randomly. You see no constant green light on top until you push or wiggle the connector on the back panel. It will work fine for a while and then drop out on its own. Anyone else having this problem? Any ideas for a fix?
Re: C/24 loses ethernet randomly
I would start by replacing the ethernet cable and take it from there. Possibly doing an ethernet reset on the C|24 would help as well.
Knowing more about your configuration and what you've tried as far as troubleshooting goes will help us immensely in diagnosing the problem. |
By an ethernet reset, you mean go to the peripherals and toggle the button for ethernet connectivity... or something internal to the C/24?
No, I haven't replaced the cable yet. Is this a cross-over or standard ethernet cable?
Depends on whether you're using a router or not. The manual will tell you, but generally you'll need a crossover cat 6 cable if you're not using a router and a standard cat 6 cable if using a router.
Replace the cable. Still not a dependable conneciton. Is there an issue with the chasis mount ethernet connection?
002 loses warmth | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-07-2006 01:50 PM |
Pro Tools Mix Bus loses db? | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-17-2003 10:37 AM |
PT loses regions | Larbabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-11-2002 04:32 PM |
PT 5 loses avi's on mac | robi3 | Pro Tools TDM Systems (Mac) | 2 | 12-01-2000 11:14 AM |
5.0.1 still loses faders | bootman | ProControl, Control|24, Command|8 | 1 | 06-29-2000 03:46 PM |
