  #51
Old 10-04-2022, 05:48 AM
Burbree Burbree is offline
Default Re: Pro Tools 2022.9 "Saving ARA Data"
Originally Posted by Diegokuuk View Post
Same here. Even after deactivating all Melodyne instances, keeps saying "Saving ARA data"
I'm on Mac OS Mojave
Had the same thing, seems to happen when a track becomes more edit dense.
Also have observed that when commiting a comp which has many regions and fades (switching off Melodyne and selecting Commit) some edits dont commit in the correct place on the timeline. Consolidating the edit and then commiting that fixes this.
Bare in mind that even when you switch off the Melodyne on a track and commit, the ARA regions created will remain in the Clip list. (You can see they have a little waveform icon next to them) So a Cmd+Shift+U will select them once you've commited your tuning and a Cmd+Shift+B will clear them out of this version of the session. This stops the Saving ARA dialog.
MacBook Pro Apple M1 Pro 32GB Mac OS 12.6.2 Pro Tools Ultimate 2022.12
_____________________________________________
  #52
Old 10-04-2022, 10:13 AM
Ru_C Ru_C is offline
Originally Posted by midnightrambler View Post
The only thing is I really like being able to use the TCE trim tool and get 'Melodyne' stretching instead of standard Elastic, I think it might actually be my favourite thing about the whole implementation. When I first tried it I thought, "Well this is obviously never going to work", shortly followed by "Woaaaaaaaaah!"
That is interesting! Does it work on grouped drum tracks? I've always found Elastic Audio a bit iffy on cymbals/overheads. Is it possible to use the Melodyne algorithm across a dozen grouped/phase-locked drum tracks?
I would try it, but I'm holding off on updating until a get a couple of jobs finished.
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2022.12, Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Mini - 16gb ram - OSX 12.6.9, PT Ultimate2023.6, Focusrite 2i2 (2nd Gen), Faderport
http://www.lostboysstudio.com
  #53
Old 10-04-2022, 05:18 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by orangepopsongs View Post
I'm constantly getting workflow interruptions with "Saving ARA Data" window. I have only two tracks with Melodyne on and both are frozen. Am I wrong in thinking ARA should not be constantly updating in the background when the tracks it's on are frozen? The interruptions are making the function unusable. Anyone know how to minimize this?
I hadn't seen this at all till today, and the reason is that I'd been engaging ARA on very short clips at a time. I'm sure most people who get this are editing long clips, such as maybe a whole lead vocal track. I tried that today, and sure enough, I saw the ARA data message. The way around this is to engage ARA on very short clips at a time, like one vocal phrase or line at a time. You can cut your vocal into short clips and edit them one at a time. It can then all be consolidated after you are done editing. That way, Melodyne doesn't have to update the whole clip after every little edit. With short clips, the message doesn't show up at all (at least in my current workflow). I hope this helps.
MSI Pro Z690-A | i913900k @ 5.5GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #54
Old 10-05-2022, 01:38 AM
thin ice thin ice is offline
I'm wondering if it might be possible to have a "disengage ARA" option in preferences. It might be better to use the old ARA trick of freezing and unfreezing a track to run audio into Melodyne if this persists.
Mac Mini M1 16 GB
OS 12.6.3
PT 2022.10
Mac Pro Quad Core
OS 10.8
PT9HD
  #55
Old 10-05-2022, 04:16 AM
PIANO2000 PIANO2000 is offline
Same issue here. I have committed all melodyned tracks and yet i keep getting this annoying message "saving ARA data". "ARA" means madness in my native language
Windows 10
Melodyne Studio
PT Studio
  #56
Old 10-05-2022, 07:06 AM
trackone trackone is offline
I believe if you use the Melodyne plugin on the track rather than the right click "Edit in Melodyne" it works as it always did.
  #57
Old 10-05-2022, 07:10 AM
oscarpatxot oscarpatxot is offline
wait wait wait, that is amazing, never thought to try that! That's the first Ill try when I get to the studio today.
  #58
Old 10-05-2022, 07:27 AM
Daveporter33765 Daveporter33765 is offline
Originally Posted by albee1952 View Post
Avid is aware of this issue and are working on a fix for the next release. Meanwhile, you are still free to use Melodyne as an insert like before(IOW, you are not forced into using the ARA version)
How in the world did a bug like this in a flagship, highly publicized, new feature get away from the developer quality control team and the beta testers?
This sounds like the kind of bug that should have easily been identified before the update was released.
Luna 1.4.4, Logic Pro 10.7.8, Cubase Pro 12.0.60, Studio One Pro 5.5.2, Pro Tools Studio 2023.6, UAD-2 software 10.2.4, PreSonus Quantum 2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 22.00, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Monterey 12.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.6.6.
  #59
Old 10-05-2022, 08:04 AM
itsjustmeee123 itsjustmeee123 is offline
Maybe it’s not a bug. Could be that’s just the way Melodyne is baked into this version of ProTools. All I know is that it could’ve been implemented a lot smoother. As I’ve said in earlier comments on this thread, with Logic Pro the ARA is seamless.
  #60
Old 10-05-2022, 08:20 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Gotta be improved - I'm back to using the plugin. The saving ARA time suck makes it a non starter for any serious Melodyne editing.
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] DaveGross Pro Tools 56 05-27-2022 09:05 AM
Pro Tools not importing volume with "import session data" lapieuvre Pro Tools 12 4 10-16-2015 06:02 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Pro Tools LE and "Import Session Data"? lydpik Tips & Tricks 5 09-11-2009 05:12 PM
