  #141
Old 12-28-2022, 10:45 AM
cmbourget's Avatar
cmbourget cmbourget is offline
Default Re: Pro Tools 2022.9 "Saving ARA Data"
I've just found a way to get rid of the (crazy and cumbersome) save function including the Melodyne (ARA) files. However, it's through the render function. But instead of rendering each clip or a set of clips, you remove the Melodyne track from the Plug-in Elastic Audio menu in the track header (renamed Plug-in Elastic Audio or ARA). At this point, a message appears informing you that all the ARA clips will be rendered (I hope you understand my English translated from French). Then, the saving is instantaneous. Phew!
  • Pro Tools 2023.6 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 4, Melodyne studio 5.
  • Softube Console 1. Two UAD systems (PCIe + USB3).
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
  #142
Old 12-28-2022, 10:49 AM
cmbourget's Avatar
See image..
  • Etc.
  #143
Old 12-28-2022, 11:37 AM
Franklyn Franklyn is offline
See image..
Yes that's fine, but you lost the editing page.
Is the 3 seconds save process (with active melodyde mode) any better in ProTools 2022.12?
  #144
Old 12-28-2022, 12:39 PM
cmbourget's Avatar
This is what I explain VS a situation where you have finished editing, because ARA keeps everything in memory (and saves it) even if you have rendered everything manually.
No, I don't see why 2022.12 would be better, nothing is announced in that sense (unfortunately).
  • Etc.
  #145
Old 12-29-2022, 02:30 AM
Vadym's Avatar
Vadym Vadym is offline
Another option here is to use the Track header context menu. Mouse right click -> Melodyne -> Render will render all ARA clips on the selected track(s) while Melodyne plug-in will stay in place for the track.
  #146
Old 12-29-2022, 02:45 AM
Vadym's Avatar
Not ideal since you will lose the possibility to edit the rendered clip.
There are two tips to decrease the annoying "Save ARA..." appearance.
1. Consolidate exact clip you going to edit with Melodyne if it was trimmed from a bigger original clip. Especially if it is 2hr record or so. Because Melodyne analyse all original file, not the trimmed clip only (for you to be able to trim out and crossfade), this results in tons of ARA data and slow saving. The less unneeded ARA data you have, the shorter Save ARA nag you will see (or won't see at all if its less than 3 sec)
2. With no new ARA edits only the very first next back-up or manual session Save will happen with "Save ARA..." nag, while all the next will use super fast cache of the previous ARA saving data. But just you made any new ARA edit(s), Pro Tools needs to reCreate and reSave in slow way the whole ARA data you have in the session (not the changes only, unfortunately).
Take it into account and I hope it will help you to reduce the annoying "Save ARA... " nags.
  #147
Old 12-29-2022, 04:29 AM
cmbourget's Avatar
Yes, thank you.
What you're explaining is precisely what I do (it's a logical path that we take right away). I consolidate the (short) clip before Melodyne and then render it. But it doesn't really work here and that's why I described the problem. ARA keeps saving a mountain of data. Even with a full render, ARA goes back to being long after a few new clips are processed, but Pro Tools sessions take even longer to save, breaking the workflow considerably.
+ the other problems, that's a lot.
See here:
https://duc.avid.com/showthread.php?t=421889
P.S. Next: I deleted the Pro Tools preferences, as it is often advised, and it's been better since. We'll see with use, but there's a big difference.
Translated with www.DeepL.com/Translator (free version)
  • Etc.
  #148
Old 12-29-2022, 05:33 AM
noiseboyuk noiseboyuk is online now
Has this issue really not been addressed in 2022.12?
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2021 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
  #149
Old 12-29-2022, 06:05 AM
cmbourget's Avatar
No, zero.
  • Etc.
  #150
Old 12-29-2022, 10:42 AM
No, zero.
Sheesh.
This very much falls into the “easy for me to say” category, but it seems crazy this hasn’t been fixed by now.
Guy Rowland
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 03:43 PM
"Error, missing PACE authorization" with PT 2022.4 and iLok USB Key [FIXED 5/27] DaveGross Pro Tools 56 05-27-2022 09:05 AM
Pro Tools not importing volume with "import session data" lapieuvre Pro Tools 12 4 10-16-2015 06:02 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Pro Tools LE and "Import Session Data"? lydpik Tips & Tricks 5 09-11-2009 05:12 PM
