When I bounce a Melodyne plugin track across to another audio track the audio sounds early during the bounce but plays back correctly afterwards...???!!!
And I think the current version of the UAD software is not reporting the correct delay, it doesn't seem to be quite right (can't remember which way). Anyone else notice these probs?
PT2022.7 - UA Apollo 16Mkii - UA Apollo 8TB Duo - Prism Lyra 2 - Mac Pro 2014 6-Core 3.5GHz 32GB RAM - OSX 10.15.7 - UAD-2 Octo - Euphonix Artist Control |
![]() Quote:
When you bounce and the track is in record mode it will sound out of time! but once you un-arm the record track it will be fine. Not having any issues with UAD 5.4. what problem are you having? They now have the same delay reading as the buffer setting!! except those that up sample for higher resolution processing, so they will have slightly more delay. Chris
If you right click on the bottom delay comp it will turn auto low latency off, making the number appear blue, and your bounced track will play in time while in input and while recording.
WernerF thanks for the hint, I had never heard of this mode before (and maybe Crizdee can benefit from it too!)
Crizdee, I've discovered the problem happens when you hit the bypass at the top of the UAD plug - there is then no delay, but the compensation is still active. So clearly, (note to self!) the answer is to use the plugin's Power button rather than the Pro Tools bypass button. However, I'm not sure what you mean by "except those that up sample for higher resolution processing". Which are those, and do they compensate correctly?
![]() Quote:
No unfortunately the UAD plugs stop all processing and release their cpu when bypassed by the plugin window, so they stop sending their delay reading to pro tools, so as you say you have to use the power button. the biggest pain for this is the 1176 which has no power button as such just a processing in?(a one way switch that can only be switched on!) then you have to press one of the other 3 buttons to bypass the processing ![]() Those that read more than the delay of the buffer setting are the one's that are being up-sampled. if your buffer is at 512 and you insert a uad plug then the standard latency will be 512 except the one's that are being up-sampled and they will read slightly more, probably 540-580. the precision EQ for example? it up-samples and processes the higher frequencies at a higher sample rate for a smoother/sweeter hi-end. Chris
Thanks for the message Chris, but actually there is a power button on the 1176 marked "OFF" at the bottom of the meter buttons on the right side! This is additional to the one at the start of the Attack knob, which indeed defeats processing but keeps the gain knobs in circuit, just like the real thing!
Oh hang on, I see what you mean. Still, I don't see the problem, you can still automate the meter buttons and drag the automation line up to any position from the bottom to switch the plugin in.
![]() Quote:
I don't want to start automating just to bypass a plugin to see whether i like what its doing or not, i would just like one on/off button? most if not all the other UAD plugs can be switched in and out by clicking the UAD Logo and the light is on/off accordingly. just the 1176 is one of the first plugs they did and they replicated the original rather than add better digital features, like they do now. also wish they would put a volume out on the precision EQ? this drives me nuts not being able to A/B the processing at the same volume. Chris
Fair comment! But these are very minor issues for me compared to, say, the nightmare of PT8 graphics and bugginess though...!!
Hi, slightly off topic perhaps but does someone know where to find a sample delay chart for the UAD plugs? Tried over at the uaudio.com and the thier forum but no luck. The only thing I found was that upsample chart in the manual p 94.
I am considering to buy the uad2 and trying to do some research. Thanks
PT 8.1cs1 HD2 Accel 10.6.4 MacPro 8 Core |
Melodyne issues...? | Jon_Atkinson | Pro Tools TDM Systems (Mac) | 7 | 08-22-2011 02:22 AM |
Timing Accuracy of Melodyne ? | Ru_C | Pro Tools TDM Systems (Mac) | 5 | 09-02-2009 12:23 PM |
MELODYNE ISSUES...... Help! | playwar187 | Pro Tools TDM Systems (Mac) | 0 | 02-14-2006 06:33 PM |
Timing Issues | HECTOR the ROBOT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-04-2004 03:13 AM |
ssc timing issues | dgamson | Digidesign Hardware & Software | 8 | 07-03-2001 06:31 PM |
