Hi all, I've been using Melodyne Uno rewired into PT HD 7.4 on a project recently.
I'm re-recording an old song with a new singer, in a new key. I'm using Melodyne to shift the old Backing Vocals up a tone, 1 track at a time, then import them back into the project. I have to say, Melodyne does an Amazing job of pitch shifting monophonic sources. Better than anything else i've tried for totally natural results. The only issue i've noticed, is that the rendered imported files, seem to be around 60 samples late...this figure varies though. Bear in mind, that i'm dropping the consolidated vocal into Melodyne, letting it work it's magic, hitting 'save', then reimporting the rendered file back into PT. So it shouldn't be a 'delay comp' issue with PT. Anyone squinted this closely at their melodyne imports before? x
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2022.12, Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Mini - 16gb ram - OSX 12.6.9, PT Ultimate2023.6, Focusrite 2i2 (2nd Gen), Faderport http://www.lostboysstudio.com |
I've noticed that they do drift a bit, back and forth within even one word or between bass notes. I use the plugin and it does the same thing when you record the audio back to another track.
AFAIK, all of the tuning tools do this. It is something to keep an eye on when tuning vocs, but usually not a deal breaker. I have had the timing shift just enough to feel a little different in both Auto-Tune and Pitch Doctor, so I have gotten used to listening for it.
I've had Melodyne show a different bpm value than the PT session so I usually key in manually to make sure the timing is the same. For some reason the time stamping of the regions was not working the way it was supposed to.
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W, Windows 10 Home. |
Ok thanks for the feedback, it least it seems we're all dealing with the same issue..
Thinking back, I've always seen 0 samples of delay and no drift when using melodyne plugin... but I route to another auto track and record, as oppose to reimport.
Maybe I'll check again to see if theres drift... anyone else with this problem with Melodyne plugin? |
Down arrow key insertion timing accuracy? | reichman | Post - Surround - Video | 6 | 03-14-2012 01:54 PM |
Two ADC timing issues - Melodyne and UAD | gonzolagonda | Pro Tools TDM Systems (Mac) | 15 | 10-06-2009 09:36 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Mac) | 2 | 09-18-2009 06:31 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Win) | 2 | 09-18-2009 12:15 AM |
Melodyne Studio 3.2 Bridge not communicating with Melodyne -- help! | nuggitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2009 03:02 PM |
