Old 01-13-2022, 07:01 AM
marsian marsian is offline
Default how to get back from VCA spill on S1
Hey all,
we are using two S1 and one Dock. When spilling VCAs, the VCA-master is on the Dock and we can get out of spill with a softkey, that responds to Control on the iPad.
Sometimes we use other apps on the iPad while mixing. If the Control app is not active on the iPad, there is no softkey to get out of spill.
In this case I found no way to get out of spill. No Eucon comand, no shortcut.
Does someone know to do that?
Thanks.
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 01-13-2022, 07:20 AM
Default Re: how to get back from VCA spill on S1
double-tap on the SEL key of the master to get into and out of folders/VCAs (at least that's how it works on the S1 and Artists). No need for an iPad or Eucon command at all.
Old 01-14-2022, 12:43 AM
HeAniganist HeAniganist is offline
on s1 press both nudge buttons together
Old 01-14-2022, 01:43 AM
Ah nice, I didn't know that one was possible as well.
Old 01-16-2022, 04:48 AM
Hey Fellows,
thank you for your suggestions!
I had VCA master assigned to the Dock. So "normal" unspill was not possible in that situation.
I will try nudge buttons trick next week.
Best
Maik
mars13.de
Old 01-16-2022, 10:03 AM
BScout BScout is offline
Well, that's confusing. It works just the same. Double tap SEL on the VCA channel to open/close. If you have the VCA master assigned to the Dock, you just do it with the SEL on the dock fader. If you are losing the VCA master, in EuControl Settings, Preferences, make sure under "Single-Master Mode" that in addition to "Assign VCA master/folder track to Dock" you have the "Lock spilled master to Dock" box checked
Old 01-18-2022, 04:22 AM
Hello BScout,
thank you for the info.
I just didn't want to switch preferences every time I need so use a different app on the iPad.
Pressing nudge buttons works like a dream
Thanks very much.
Cheers
Maik
mars13.de
Can we have VCA spill without the app sometime pls? Led Artist Series 0 05-06-2019 04:51 AM
Cannot spill all layouts to R Spill zone Schottlandru Avid S4/S6 5 10-29-2017 04:21 AM
Grp Spill dez811 Avid S1, S3, Dock and Control App 1 01-26-2017 07:51 PM
VCA Spill msw Avid S1, S3, Dock and Control App 2 10-19-2016 07:50 PM
S3L VCA Spill Soundrambo VENUE Live Sound Systems 8 11-04-2013 07:51 AM
