Old 03-04-2006, 03:57 PM
johansen johansen is offline
Default Fader speed
Hi everyone,
My C8 faders have much more speed going down than up... is this supposed to happen?
regards
Old 03-07-2006, 02:26 AM
El Steffo El Steffo is offline
Default Re: Fader speed
Can't speak for inside PT (since my command|8 is permanently offline - see other post ), but there is a HW test:
  • Press F1: Utility button
  • Press Select button on fader 2 strip ("Fader")
  • Press Select button on fader 2 strip again ("FadTst")
This starts a test. The faders go bottom-middle-top-middle back to bottom in a cycle. On my Command|8, it is the same up as down - fast!
To exit, press select(8) or F1: Utility.
Hey - wait a minute - just tried the Fader Group test: Yes, they are marginally faster down than up. But if I hadn't read this post, I would not have noticed. We're talking 10ths of a second here.
Hope this helps!
Cheers,
Stefan
Old 03-08-2006, 03:14 PM
Hi
Well, i did those tests, my faders are fast going down, but going up they are half speed or so it seems, this gets really annoying in fast fader movements.
regards
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
Film Speed/Video Speed Workflow Confusion! subwoof Post - Surround - Video 13 08-23-2008 09:03 PM
Playback at double speed / higher speed in LE? Chris Nelson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2008 09:28 AM
shortcuts for half speed +dbl speed recoring neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-09-2003 02:48 PM
