Old 05-09-2016, 02:17 PM
larsongs larsongs is offline
Default What's your Technique? Mixing Bass & Kick
Feel like sharing your Technique? Secret? Tips?
Thanks
Old 05-11-2016, 10:56 PM
Default Re: What's your Technique? Mixing Bass & Kick
I saw this on YouTube & thought it was good.
From Recording Revolution
Any other thoughts on this subject?
http://youtu.be/ECRx4WF3pcc
Old 05-12-2016, 05:37 AM
Drew Mazurek's Avatar
Sorry, but as usual, sites like RR latch on to something someone famous said and turn it into overblown content. Gotta get those page views!!
That is a simple little thing someone does to help them predict their "gain staging" at the stereo buss. It doesn't in any way shape or form help you mix the kick and bass well sonically. I'd hate for you to think it does.
www.drewmazurek.com
Old 05-12-2016, 06:55 AM
Marsdy Marsdy is offline
One tip I use.... If there's a noticeably pitched element to the bass drum, notch that out with an EQ and shorten it's length if it's ringy with a transient manipulator plug in.
That way you're not going to get note clashes with the bass guitar that can really mush up the bass end, especially if the interval between the kick note and the bass note is jarring.
Dave Marsden
UK
Old 05-12-2016, 08:22 AM
EGS's Avatar
EGS EGS is offline
I cut the "boxiness" frequency in the kik, somewhere around 150-200 hz, with a notch EQ. I do a similar cut to the bass, but at a different frequency. Add "snap" to the kik by boosting an upper-mid frequency. Do a similar boost to the bass, but at a different frequency. Sometimes on kik I'll use some downward expansion, i.e. gating with about 6-9db of range. Pan kik & bass slightly - 11 & 1 o'clock. To get sub-frequencies from the kik, copy the track and pitch it down by 1 octave. Get rid of the digital artifacts on this pitched track by applying a high & low pass filter. Compress both the kik & the bass. Monitor on big/medium/small speakers plus also headphones. My favorite speaker for this is the Tivoli Audio Model One. My 2 cents!!!
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001
Click for audio/video demo
Click for resume
Old 05-12-2016, 12:23 PM
YYR123's Avatar
YYR123 YYR123 is offline
I hate to plug sites, but I bought the Andrew Schepps mixes Ziggy Marley videos and he has some cool ideas about how he busses the kick/snare (I think he used the whole set) and bass - paralleled them and mixed them back in.....
I can't remember exactly but he said the console he was using had a quad buss, that fed the 2track buss....anyway he paralleled quite a few of his instruments and brought them back in....it does change the depth of the return and sound.....when mixed back in.
As I understand it - due to the different comps on the paralleled buss versus the comp on the actual track.
Not talking a huge amount of compression either....
Daniel
Old 05-13-2016, 05:17 AM
Wireline Wireline is online now
As always, it completely depends on what you are after. One old school approach I used with some success: putting the bass dum and bass guitar together on their own aux, with a buss compressor. This came from waaaaaay back when we used to take a kick mic and plug it into the second channel of the bass amp. The kick pushing the power tubes into compression produced a very nice leveling and auto duck effect
Ken Morgan
Midland, TX
A Musical Nobody Since 1972
2017 Intel Mac Mini, 32G, PT 2024.6.0 Studio, Presonus Quantum 2626 or 1824C (whichever works) and a bunch of stuff via ADAT
Old 05-13-2016, 10:14 AM
JFreak's Avatar
JFreak JFreak is offline
cut kick around 400Hz (boxiness) and boost bass around 2kHz (fingers), blend Q to taste
Janne
Old 05-13-2016, 10:29 AM
That's a good place to start.
About the boxiness thing. There's that famous old trick to hunt down the exact boxy frequency or any other nasty, peaky frequency for that matter.
1. Turn down your monitors... VERY IMPORTANT!!!
2. Turn the bandwidth control of a mid EQ to the narrowest bandwidth/Q
3. Boost that frequency a LOT!!!!
4. Slowly sweep the frequency up and down and you WILL hear the nasty frequency very clearly when you hit it. (It helps to hold down [command] on the Mac to sweep more precisely.)
5. Cut that frequency and then widen the bandwidth to taste.
6. One thing to be aware of... You need to make sure you're not hitting and cutting the fundamental frequency of a note or any of it's related upper harmonics i.e. an octave higher.
It works for boosting too. Not very fashionable but I really like the Avid EQ3 for pulling back nasty frequency content.
Dave Marsden
UK
Old 05-13-2016, 02:34 PM
DonaldM's Avatar
DonaldM DonaldM is offline
[snip]
I hear the term "boxiness" a lot, but not sure what it means. Are there audio samples of this out there somewhere? I'd like to hear what exactly this is referring to. Thanks.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Win-11/PT 2024.10/i9-14900K/Gigabye Z790MB/64GB RAM DDR5
Kick and Bass mixing marklioneldavis Tips & Tricks 2 12-08-2009 08:36 PM
Mic selection and technique for upright Bass Randirainbow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-31-2006 09:26 AM
RE20 kick drum technique cuttooth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-28-2003 08:48 AM
Any sugestions on bass drum mic technique? mikerica101996 General Discussion 7 09-18-2002 09:57 AM
bass / kick and bass management AdamFrick Post - Surround - Video 7 12-26-2001 07:52 AM
