Keyboard shortcut - Display Mixer
I'm wondering why I can't show the mixer window through the keyboard shortcut 'Ctrl+=' as reported in the 'Display' menu. I'm using an italian keyboard layout, and the '=' symbol is obtained by using shift plus the zero key (the regular one, not the one in the numeric pad).
I've tried to change my keyboard layout to International English, where the '=' is the key at the very left of the backspace key, but even in this case I've obtained no mixer window pressing ctrl+= . Anyone can help me ? |
Re: Keyboard shortcut - Display Mixer
Did you try the = key on the numeric pad, or is it that you are using a Laptop that has none?
This may seem obvious, but if you have an extended keyboard, use the = key on the numeric pad and verify that you have Num Lock activated. It has happened to me before. On an english layout keyboard, the = key is over the 8 key on the numeric pad. I know that in non-english keyboards there is no = key on the Num Pad, instead, there is the / key. Maybe you could try that one, with the layout set to international english (try also US English). On the other hand, you could get an english keyboard and change the language everytime you launch PT. |
Air Display iPad app & PT (Mixer Problem) | Earthling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-15-2011 05:17 PM |
Unlinking Arrange and Mixer Channel Display | Simsy | Pro Tools TDM Systems (Mac) | 0 | 08-05-2009 10:21 AM |
PT8 switching between mixer/edit one-key-shortcut | erans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2009 04:14 PM |
how to get the mixer to display level in decibels? | sonicz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-03-2006 02:46 PM |
Shortcut for automation display? | 6X 2 | Tips & Tricks | 7 | 05-31-2002 09:33 AM |
