Old 01-07-2017, 10:47 AM
fsguerra fsguerra is offline
Default Inconsistent S3 to MacPro Connection
Someone, anyone, please help.
I opened a case (03115684) on 1/2/2017 with Avid reporting a "Network Error" message from EuControl: "Unable to connect to the unit named "SMMix CS (Avid S3). The network address of this unit appears to be set incorrectly".
The person on the support phone line couldn't help. Then I received an email from someone who provided basic troubleshooting (i.e., uninstall, delete preferences, reboot). Nothing worked.
I requested that someone give me a call to get this controller connected again but no one from Avid has responded to the case or called me back in several days.
Is this the level of support I'm paying for on an annual basis? If so, I think you should lower the price.
Please assist.
Mac Pro (Late 2013)
macOS Sierra 10.12.2
Processor 3 GHz 8-Core Intel Xeon E5
Memory 32 GB 1866 MHz DDR3
S3
Artist Transport
Pro Tools 12.7
EuControl 3.5
AirPort Extreme
Regards,
Francisco
Old 01-07-2017, 10:53 AM
Southsidemusic's Avatar
Default Re: Inconsistent S3 to MacPro Connection
Hey Buddy
I have forwarded this to Avid and someone will contact you via PM/Email or phone.
Sorry to hear about this and hopefully it will be sorted out quickly.
Best Wishes
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-07-2017, 11:05 AM
Thanks, Christopher. I really appreciate it.
Regards,
Francisco
Old 01-07-2017, 12:01 PM
Glad to help. Avid has been alerted now and are on the case you had opened so hang in there and someone from Avid will respond to this.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-08-2017, 04:31 AM
JRChappell JRChappell is offline
I am having the exact same issue. I have tried connecting directly to my second network port as well as to my router. It works fine with the artist mix plugged into the same port. My S3 will connect for about 20 minutes and then lose the connection.
I am on vacation now. I am hoping to get this figured out on the 19th when I return.
Mac Pro (Late 2013)
Protools 12.6
Avid S3
Old 01-15-2017, 04:54 PM
Avid Customer Support contacted me over the phone. The support rep requested that I remove the AirPort Extreme from my configuration, connect the S3 directly to the 2nd ethernet port on the Mac Pro, then daisy chain the Transport into the S3.
Although the EuControl software recognizes the peripherals in the new configuration, this is not the optimal configuration for me. When I first ran across this issue, a Euphonix support person was able to get my configuration working through a router.
Is there any support documentation available to support a configuration with a router? I know it's possible. It worked for about 1 year... then it stopped working.
No rush... but it would be nice to know this is supported. :)
Regards,
Francisco
Old 01-12-2018, 11:26 PM
RogerPaolo RogerPaolo is offline
I have a question about this. In the manual it states that if you want to use transport you will have to use a router to connect them. For me that does not work as my airport extreme does not support AVB so I skipped that option. But from what I read from your post it's possible to daisy chain the transport trough the S3 to my Macbook, and I would not need to use the Airport in the config. So AVB would still be available. Am I right?
Why is PT inconsistent ?? JLEpperson Pro Tools HDX & HD Native Systems (Mac) 0 11-26-2013 11:46 AM
Inconsistent volume levels EarHole Post - Surround - Video 7 05-03-2012 02:06 AM
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 02:39 PM
Inconsistent Click Track xx1messxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-23-2011 10:33 AM
MacPro connection with Macbook Pro!! digidesignboarder General Discussion 10 12-31-2009 05:26 PM
