Changing Buffer Size
I need to figure out how to change the buffer size on a firepod so it will work with protools 9. keep getting the msg , You audio device is configured with a unsupported audio beffer size. Please select one of the following buffer sizes in the device control panel. 32,64,128,256, and os on. when opening the control panel ther is only latency.
anyone know where or how to change so i can use this unit. Thanks |
Re: Changing Buffer Size
You are not the only one dealing with this issue, I have a focusrite saffire 6 and I cant make it work I get the same message you got. I hope somebody knows how to solve this. |
I solved it with ASIO4ALL ( http://www.asio4all.de - only for Windows).
Install it, and set PT to the ASIO4ALL driver. Then, set a new path in I/O config (I named it Apogee), change the OUT on all channels with the new one, and you should be very happy Note : buffer size should be the same in Pro Tools 9 -AND- in Asio4All ... (asio4all control panel is only available from INSIDE your audio app) Working fine with Rosetta 200 + X-Firewire card. Hope this helps.
Apogee Rosetta 200 + X-Firewire option Mbox 2 Pro Sonic Core Scope RME 9632 PT9 HP Quad Windows 7 MBPro OSX 10.6.5 http://www.aellekappa.com |
10.1.2 Crash when changing Buffer Size | Erik318 | Pro Tools 10 | 3 | 11-14-2012 06:49 AM |
No audio when changing buffer size in Pro Tools 9 | asaffulks | Windows | 9 | 01-16-2011 12:48 AM |
HELP: Changing buffer size in CoreAudio Manger? (SEE PIC) | tokolosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-23-2009 09:25 AM |
Reason out of sync after changing buffer size | jhan303 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-20-2009 08:45 AM |
Mbox-changing buffer size outside protools | MOR01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 12:50 PM |
