Cntrl24 connection with 002 Rack
Please advice the connections of Control 24 with 002 Rack,Wht abt the Monitor Out puts?25 pin Connection how will i connect stereo monitors?
Re: Cntrl24 connection with 002 Rack
you'll need a snake that goes from the 25 pin connector to whatever plug you need for your monitors...probably XLR or TRS. Make sure it is the correct pin-out for the C24. This info can be found in the manual.
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
After making many cables over the years, IMO it is easier to buy the Digi snake than to make one yourself. They are relatively inexpensive compared to the time it takes to buy the bits and make your own - Unless you want to make your own out of top quality bits (gold connertors, the best cables ($20 per ft and up)
11 Rack to PC Connection Problem - Help Please | InnerSpark | Eleven Rack | 10 | 07-28-2013 04:46 AM |
003 Rack+ losing connection with PT8 | shredder12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-25-2009 10:46 AM |
Connection Sub to 003 rack | bkwalker510 | General Discussion | 0 | 12-29-2008 05:46 PM |
002 Rack Connection Issue | Trifektor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-27-2008 10:20 AM |
002 rack unable to keep its connection | dumdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 07-05-2005 05:07 AM |
