Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 03-29-2017, 12:15 PM
Rpro Rpro is offline
Default System 5 Side-Chain from surface
I am looking into side-chaining piano to strings compression or kick drum to bass guitar compression.
On the S5 surface I have the compressor on (Bass) channel 1 and kick on channel 2. On the bass channel I enabled SC then select channel, key or link. When set to key the bass track is muted as it should but now I select channel and want to grab the kick drum channel but cannot figure out how.
I know side-chain within eMix and Nuendo works but I would like to quickly setup side-chain from the S5 surface.
Can someone in S5 land chime in?
Windows Pro 10 X64 - Pro Tools 12.8HDX
Windows Pro 10 X64 - Nuendo 10
Windows Pro 10 X64 - Cubase Pro 10
Euphonix System 5, 408's, 401, 402, 403
eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1
Old 03-29-2017, 07:36 PM
EddieJones's Avatar
Default Re: System 5 Side-Chain from surface
Have you patched the side chain ? (I presume you are talking S5 DSP not EUCON ?)
Is it possible to side-chain an EQ? Herkimer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-03-2009 06:00 PM
How do I set up a Side Chain junglelabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-30-2007 10:49 PM
Side Chain ByPass Tips & Tricks 1 05-08-2007 12:33 PM
A better way to side chain? studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-24-2007 04:40 PM
Side Chain Processing tbp04 Tips & Tricks 6 01-03-2007 03:04 AM
