Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 01-11-2017, 05:51 PM
Rpro Rpro is offline
Default Panning group busses on S5
Mixing 18 tracks of drums on the S5 along with other instruments. I assigned groups buss 1 and 2 to a few strips. I send the kicks, snare and tom tracks to group buss 1 and 2 and assign the group busses to the mix buss and remove the source tracks from the mix buss. The source tracks are panned appropriately but there is no way to pan the group buss. The reason for this is to insert external EQ and compression to drive the drums hard. The issue is that the group busses are dead center. The pan button won't activate. On my DM2000 I can pan the group busses hard left and right.
I need a way to pan group busses. Any thoughts are welcome.
Thanks
Windows Pro 10 X64 - Pro Tools 12.8HDX
Windows Pro 10 X64 - Nuendo 10
Windows Pro 10 X64 - Cubase Pro 10
Euphonix System 5, 408's, 401, 402, 403
eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1
Old 01-12-2017, 09:49 AM
Steven1145 Steven1145 is offline
Default Re: Panning group busses on S5
Have you checked the pan format of your group busses in eMix? It is in the BUSSES -> Groups section. You can right-click on the busses you want, and assign their "format". You would need to assign them as L and R of a stereo record Group. If they show M, it's that they are mono and the panner is probably made inactive.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 01-12-2017, 02:24 PM
Yes I have checked the pan format in eMix.
Ok I resolved the panning issue.
On the strips where you place the group busses you assign them to the mix buss but now press the knob to spill the stereo or 5.1 channels. In stereo remove R St from the left group buss and remove L St from the right group buss. In Patchnet go to Console IO then group busses and patch in your favorite outboard comps and EQs. On the S5 Hit the insert button on each buss. Done!
USB Busses Mac Pro TCLguy1 FireWire & USB Audio Interfaces (Mac) 0 08-31-2016 06:52 PM
Problem with effect send and group busses and mixing RedMagpie General Discussion 7 05-12-2016 11:28 PM
1 track in group isn't responding with group! gregwor macOS 7 01-25-2011 07:22 PM
Busses Nick Jarl Pro Tools TDM Systems (Mac) 6 04-27-2009 08:13 AM
Group Persists for Resizing Even When Group Turned Off. holden Pro Tools TDM Systems (Mac) 3 06-24-2008 03:31 PM
