Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-28-2002, 09:39 PM
aziel aziel is offline
Default Mogami cables...
I heard that Mogami is the best brand in audio cables, i saw then, but i don´t really know wich model i have to use...it is a good idea buy the cable per feet and then ad the neutrik´s ?
PD: sorry about my english... [img]images/icons/grin.gif[/img]
Old 11-29-2002, 08:43 AM
rmx rmx is offline
Default Re: Mogami cables...
I use Mogami 2534...
Rob
Old 11-29-2002, 09:04 AM
CO2 CO2 is offline
Hello aziel:
Your choice of cable is sort of the same as your choice of studio monitors. Once you get to the high end manufacturers, you will find that all of them do a relatively great job. It is very subjective to say which is best.
I use Canare Star-Quad, Mogami and Monster in my studio.
The Canare is my main point to point cable for balanced connections. I used it to connect virtually everything that is hard wired (including my patchbays). Each of the High and Low signals in a Star-Quad cable is represented by 2 conducters, which comprises 5 conducters (plus drain). This cable is incredible for RF noise suppression, but a bit more work to use (just for the extra 2 conducters per connection).
I also use Canare 110 Ohm cable for all of my digital interconnects.
I use Mogami for all of my portable gear and snakes. Mogami is GREAT. It is a breeze to work with and it is absolutely flexible and resilient. It withstands the constant wrapping and unwrapping and has never failed. (Mogami's multipair audio cable is its MG-293x series ... x varies with the number of conductors)
I use Monster for all of my microphone and instrument cables. I suppose I have succumbed to Monster's transparency and time alignment hype. I'm sure there are many detractors here who would say there are no differences between Monster and other mic and instrument cables, but I HEAR them. Using Monster is like having a veil lifted off your microphone or instrument.
In fairness, I have used each of these 3 manufacturers products interchangeably and have not been unhappy with any of them. There are many other great cable manufacturers as well (Belden and Gepco come to mind). My current cable choices have just been the result of my own personal process of refinement.
Soldering your own connectors is a cost saving and, usually in the realm of studio wiring, necessary option due to the custom nature of each installation. As long as you are careful and proficient at wiring, you can do a very high quality job at a fraction of the cost of purchasing prewired harnesses or hiring someone to wire for you. Neutrik is also my connector of choice, but once again there are many other fine connectors such as Canare and Switchcraft.
I wish you great success!
Best Regards
Old 11-29-2002, 09:39 AM
The Chinese The Chinese is offline
My Suggestion is this- If you can use a soldering iron well, then it pays to make you own cables. If you have any doubts, don't. As for cable, Mogami, Belden, Canare, Gepco are all great. Aziel, there is a LOT of hype on this subject, and the bottom line is that 99.99% of people/manufacturers could not hear the difference is a double blind test. Spend money, but don't feel you have to get the most expensive cable just because someone told you to.
-Todd A.
Old 11-29-2002, 11:50 AM
CO2 CO2 is offline
Hello Todd:
My point exactly! (keyword: subjective)
[img]images/icons/smile.gif[/img]
Thank you.
Best Regards
Old 11-29-2002, 02:33 PM
Brent Hahn Brent Hahn is offline
If you're making up TT patch cables, you might want to avoid the Canare Star-Quad. Too bulky.
BH
Brent Hahn
http://www.radioactive.la
Old 11-29-2002, 06:37 PM
CO2 CO2 is offline
Hello Brent:
You are right. Star-Quad is a BIT unwieldly but it was worth the effort!
Best Regards
Old 12-01-2002, 07:32 PM
Guest
Posts: n/a
Default Post deleted by Digidesign
Old 12-01-2002, 08:04 PM
Felix Felix is offline
Rapco makes just as good cables for relatively less.
the road hog series i think is the one i have.
Old 12-01-2002, 10:09 PM
A1's Avatar
A1 A1 is offline
I totally agree with Todd and CO2.
Just about every brand uses the same material so there is no difference in the sonic quality.
If you want to go with the "life time warranty" type of cables and pay extra $ its fine.
Bottom line is that the recording, electronic and cabling technology changes so fast that you won't keep your cables for long enough to see the durability difference.
Mogami and Canare cables Alternative ! sputnik33 Pro Tools TDM Systems (Mac) 11 05-11-2008 08:10 AM
Mogami or Canare cables? Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-08-2006 09:44 PM
Where do I get mogami cables in Australia? Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2005 01:46 AM
Mogami or Monster Cables ps500 Tips & Tricks 7 06-15-2005 12:05 AM
Monster, Mogami patch cables etc......? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-08-2003 02:18 PM
