Old 09-04-2009, 12:28 PM
Speeder Speeder is offline
Default Axiom Pro 61 Patch Select
Should I be able to scroll through patches in an instrument plugin such as Xpand using the 61? I was hoping I could review patches without going through all of those windows. None of the keys seem to have any effect on the voice selection.
Old 09-04-2009, 07:49 PM
RussUK RussUK is offline
Default Re: Axiom Pro 61 Patch Select
Nope - it's not part of the protocol. You can use the review option in the plugin itself which will autoscroll for you as you play at a predetermined period.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 09-06-2009, 09:38 AM
burningbusch burningbusch is offline
Press F1 to get into INSTRUMENT MODE (you should see "Plugin" above Soft 2, not "Ins"). Then HOLD Soft-2 while pressing Soft 3/4 to scroll through presets. This will work with any soft synth that has presets saved in the Protools preset system.
See the HyperControl Guide for ProTools for more info.
Busch.
Select Next Track using Axiom 61? Jeanpaul MIDI 5 09-25-2011 08:42 PM
no midi patch select in mix window? lbar11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-22-2009 11:02 AM
Is there a quick way to select next patch in a folder from structure? crizdee Virtual Instruments 5 08-06-2009 11:57 AM
Patch select problems sevenson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2009 08:04 AM
CRASH when i try to select MIDI patch minister Pro Tools TDM Systems (Mac) 3 08-09-2005 12:02 PM
