MIDI SET UP WITH SOUND MODULE
IM USING PROTOOLS 7.4 WITH M BOX 2, A MOTIF RACK ES WITH A M AUDIO KEY RIG. IM LOST I DO A MIDI STUDIO SET UP AND MY USB KEYBOARD ENDS UP UNDER THE PREDEFINED MENU WHEN I SET UP
A MIDI TRACK. WHEN I TAP KEYS THE VOLUME SLIDERS MOVE UP AND DOWN BUT CANT SEEM TO GET MY SOUND MODULE ON THE SAME PAGE. PHYSICAL CONNECTION ARE GOOD I JUST DONT UNDERSTAND, IM SO STRESSED PLEASE HELP IM GOING TO JUMP. |
Re: MIDI SET UP WITH SOUND MODULE
OK, first things first; please, STOP SHOUTING.
Next, What is it exactly that you are trying to do? You said you have the M-Audio Keyrig Virtual instrument, the Rack ES, and a USB MIDI Keyboard? Which USB keyboard specifically? Do you have the proper updated drivers installed? What platform? (MAC or PC?) How are you connecting the Motif? There should be only one item you need to setup in the MIDI Studio Setup; the Motif. The USB keyboard can be selected by it's generic driver name on MIDI/Instrument tracks and doesn't really need to be setup in the MIDI Studio Setup at all. The only benefit would be to change the name on the menu so that it would be more recognizable to you. As for how to use the KeyRig, maybe my Softsynth tutorial on <a href="http://www.ptnewbie.com" target="_blank">www.ptnewbie.com</a> would help?
the name of the keyboard is m audio key rig 49. i'm trying to play the motif rack with the key rig and use pro tools as my sequencer. i just can't figure it out. i don't wanna use the virtual instrument.
Ah. Now I understand.
M-Audio also has a Virtual Instrument product named KeyRig (why they do that, I don't know), and you didn't really indicate in your first post that you were referring to your USB controller as the KeyRig 49, so answering that question helps a lot. You still need to answer some of the other questions I asked though, please; Do you have the proper updated drivers for the KeyRig 49 installed? What platform? (MAC or PC?) How are you connecting the Motif? I need this information to better assist you. Thanks.
Do you have the proper updated drivers for the KeyRig 49 installed? yeah What platform? (MAC or PC?) pc How are you connecting the Motif? midi in and out to the mbox 2 and audio out of the motif to the m box 2 |
Seriously, if the keyrig is connected properly, and your computer recognizes it, this is all you have to do:
That's really all there is to it. Have you tried those steps? If you have, what part is failing? With the gear that you are using, there really is no reason to muck about in the MIDI Studio Setup (yet).
you are a life saver im sure i will have more questions to come. maybe you should have written the manual.
well i thought that fixed my problem but it didn't but i figured out my fix. in my motif manual in small writing with an asterik in front of it it said if using an usb interface you must use usb to connect motif and computer. no midi cables at all. i feel so small. thanks for your help
Recommendation for a midi sound module | MickFowler | MIDI | 0 | 10-05-2010 05:51 PM |
Need to run MIDI track from PT through a sound module | Amnesiac | MIDI | 11 | 02-11-2008 05:08 AM |
help on choosing midi sound module | tantejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-30-2002 02:14 PM |
Connecting MIDI sound module to 001 | ventri000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-15-2001 11:12 AM |
Midi Sound Module recomendations? | Forrest77 | MIDI | 8 | 05-12-2001 01:42 AM |
