CRASH when i try to select MIDI patch
mac g5, os 10.3.9, PT 6.9.1, HD|2, 2 GIG Ram
everytime i try to select a MIDI patch for my Lexicon PCM91 (connected via MIDI and AES) PRO TOOLS crashes. what is odd is, it is ONLY with this unit. i can sucessfully select patches in my Eventide Eclipse, my, Roland XV5050, my Oberheim OB•12, my Ensoniq DP/4. what i do is, in the mix window, on the MIDI track i click on the patch icon in the lower left. when i select the PCM91 on Midi channel 4, connected through my amt|8, PT crashes. other midi channels, i click, and, no problem, opens patch window. i select a patch, the unit responds and i move on. i tried trashing all prefs, toss databases, rebuilt my AUDIO/MIDI setup. checked my cables...same thing... never had this with 6.7, started with 6.9. i also don't believe it is session specific; it happens in evry sessio i try this in. my work around is to go to the edit window and do a patch change command on the MIDI track there. but sometimes that crashes it. yes, i can change the patch by hand, but then i can't save my patch with the session. AND i use midi to contorl the boxes parameters overtime, and in some cases, when it isn't needed for a moment, switch patches in a session. guess i could try cs2 and/or re-insatll PT and rebuild my MIDI setup again.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: CRASH when i try to select MIDI patch
It's not quite clear from your post - are you saying that the PCM91 patch selection causes PT to crash ONLY when it's on MIDI channel 4, but on other channels it works fine?
You might want to try replacing the patch file - it may have been corrupted somehow. Also, where did you get the middev and midnam files for the PCM91? |
no, i didn't say that exctly. i have not changed the MIDI channel of the device. but it is more likely the below problem. now, when i select the PCM91 on a midi channel, PT crashes. rats! more trashing and reconfiguring. Quote:
thanks!
i use mine the same way..works every time...i use only channel one midi.and have channel one selected on the lex to send and recieve..also make sure that gm or anything else is not checked in the midi setup window..
www.garyvandy.com |
no midi patch select in mix window? | lbar11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-22-2009 11:02 AM |
Crash when selecting MIDI patch name ?? | bennym | MIDI | 1 | 02-09-2009 10:01 AM |
Progamming sound module into midi patch select | positive crew | Tips & Tricks | 3 | 01-29-2006 10:31 AM |
Midi Patch Name Crash !!! | adesound | Pro Tools TDM Systems (Mac) | 4 | 01-13-2005 11:12 AM |
Midi Program Button (Patch Select Dialog Box) | cc1 | Pro Tools TDM Systems (Mac) | 0 | 05-22-2004 11:13 PM |
