10 tracks in a session
No plug ins instantiated Clean install of 10.5 Combo updater to 10.5.5 clean install of all plug ins with latest versions Dual 2.7 G5 6 gigs ram Both drives were just reformatted (low level erase -1 pass erase) Hitachi deskstar 2 partitions 75 gig System 425 gig storage WD raptor 80 gig for audio System Drive De-fragmanted with Disk warrior to create clean Carbon Copy Cloner in case of errors... this session was the first test after that was created. I did other tests with a couple crashes along the way but the system has been rebuilt from scratch and I was not done with everything so i didn't really worry about it much Heres a link to the crash log and the system specs from the trouble shooting folder. CrashLog |
Ok same specs as before but I disconnected any firewire drives.
used the "trash prefs and databases files" utility after the last crash. emptied trash and restarted repaired permissions and shut down. . . a minute later started up then opened the session started on the same session i spoke of earlier. 10 audio tracks no plug ins or VI's. this second crash occurred when I tried to change the tempo after muting a newly consolidated audio region. same this happend previous to the last crash... I was changing the tempo. I am making edits of a bunch of songs and each song has a different tempo so as I move from one song to the other i change the tempo to make grid editing easy. after the last crash i was able to do this about 5 different times until the crash. . somewhere around the same number of tempo changes i did before the last crash. I am changing the tempo while playback is stopped and all regions are muted (after finishing the last edit I consolidate and mute then move on the the next track resizing the tracks as needed to move from one to another) Crash Log 2 |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 09:53 AM |
Kernel Panic/ Crash Hell- fresh install, what now? | DoubleDigit | Pro Tools TDM Systems (Mac) | 5 | 09-28-2011 03:53 PM |
fresh install | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2008 10:22 AM |
Fresh Install? | carnology | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-16-2005 05:39 PM |
How to install fresh OS? | BigALW1414 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-20-2004 03:05 PM |
