Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-16-2008, 12:57 AM
Employee24 Employee24 is offline
Default 7.4.2 install crash at digirack
Getting kinda worried here. I've been all over the forums, and no one has a solution yet. I'm running os x 10.4.10, and everytime I try to install pt le it crashes when it gets to the digirack. The only info it gives me is that it couldn't install some files, then it tells me to try again.
Old 11-16-2008, 04:12 AM
Premo Premo is offline
Default Re: 7.4.2 install crash at digirack
You need to click the black arrow next to the PRo Tools M-Powered (top most option) to reveal the sub install options at the "custom install screen" where all the check boxes are.
Then uncheck digirack and free bomb factory. Now install just the application files and Digi Core audio manager. Once that completes, itll make u restart. Now run installer again and do the reverse. Install only Free BF and Digirack and uncheck the other 2 and it should work.
If it's not working, which is rare, then repair disk permissions, check permissions on your Library / app support / Digidesign
folder to make sure it's read and write
if still not working try doing and OS combo update again or reinstall the OS.
Old 11-16-2008, 11:20 AM
mradlauer1 mradlauer1 is offline
From my understanding 7.4.2 was only designed to work on Leopard...10.5 and above?? maybe digisupport can clear that up.
White Macbook OSX 10.5.5 2.2Ghz Core 2 duo 4Gb RAM
PTMP 7.4.2
M-Audio Profire 2626 and Focusrite 26 I/O via lightpipe.
Focusrite Platinum Voicemaster Pro
KRK RP8's
1Tb Dual drive array.
Fresh PT 8 and OS install CRASH Shifted Music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2009 12:53 PM
7.3 Install crash / will not install digirack Leif Shackelford Pro Tools M-Powered (Mac) 2 04-18-2007 08:46 PM
Crash on PTLE 7.0 Install - Please Help Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-28-2005 10:50 AM
Crash During XP Install, Help needed. gerax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-15-2002 12:05 PM
DP problem- Can't install w/o crash patman Pro Tools TDM Systems (Mac) 3 09-13-2002 12:01 AM
