When I record from Reason (as a plug-in, the full version) I see no waveform appear in PT. Why is this?
cheers |
Are you bussing it to an Audio Track? Inserts across Audio Tracks are after the record buffer.
Rail
Yes, I am bussing it to an audio track. What I am trying to do is lay down drums using Reason, then record basslines from my guitar over them in PT. I have programmed a sequence in Reason, then I open it as an insert, and when I put it in record mode and press play, it seems like it lays it down but I see nothing appear in PT.
If you are trying to capture the actual audio out from reason as a waveform in PT, you have to put Reason on an Aux and bus to a rec enabled Audio track.
But unless you're going to modify the resulting audio file in some way, it is not necessary. That's really the whole point of it.
MDW aax V5 not appearing in list??? | PT user | Windows | 2 | 08-25-2013 01:35 AM |
Waves TDM not appearing in PT 10 HDX | Cliffy_Boy | Pro Tools 10 | 12 | 12-26-2011 08:58 PM |
Calculate waveform - where are waveform views stored? | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2010 08:18 AM |
Recording waveform not appearing | manyrains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2009 10:50 AM |
MBox2 not appearing in AMS | DaveHighet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-24-2008 09:25 AM |
