Old 07-08-2007, 06:39 AM
ballermann666 ballermann666 is offline
Default CPU overload issue
Hi there,
after a few seconds i get this message: "A CPU Overload error occured. If it happens often try increasing the "H/W Buffer Size in the Playback Engine Dialog, or removing some plug-ins (-6101)"
This happens everytime, even if only 1 audiotrack w/ NO plugins is enabled. I have already increased the buffer to 2048 samples with no effect. CPU usage is around 2-4 percent (1 audiotrack, no plugins).
Makes PT practically unusable for me. I don't have CPU issues with applications such as Ableton Live.
Powermac G4 Dual 1.7Ghz (GigaDesigns CPU Update)
1 GB RAM
MacOS 10.4.9
M-Box 2
PTLE 7.3 - same error occurs w/ PTLE 6.8.1
energy/filevault etc. is off.
Old 07-08-2007, 09:55 AM
Slim Shady Slim Shady is offline
Default Re: CPU overload issue
Lots of problems there - the biggest being you're using a CPU upgrade that isn't supported, so that kinda kills any help anyone can give you right off the bat. You could try adding more RAM, and of course all the stuff in the "General Troubleshooting" thread might help, but I've seen several CPU upgrades that made PT not work before, unfortunately you might be in that boat too.
Old 07-08-2007, 09:11 PM
Thanks for your reply, Slim.
Guess i have 2 options there. Either selling the Mac/buying a new one or selling the M-Box.
I think i'm gonna opt for the latter, since the Mac is still working fine w/ other apps.
Old 07-08-2007, 09:52 PM
Does it do the same thing if you set the playback engine to 1 CPU instead of 2?
Old 07-09-2007, 04:23 PM
raphael_audio raphael_audio is offline
It's happening to me also. I've got a mac mini Intel Core Duo 1.66Ghz and OSX 10.4.9 (updated by the combo download, as the digidesign site says).
The system was ok when I was using PT 7.1.1. When I instaled 7.3.1 it became unusable. I switched back to 7.1.1 and it works just fine.
Any idea what's goingo on!!
Old 07-09-2007, 04:26 PM
By the way, I have a 002 rack.
Old 07-12-2007, 05:23 AM
Did that and it runs smoothly without error messages since about 3 hours now. CPU load is quite high though (~20% @ 4 tracks/6 plugs).
Thanks.
CPU Overload Abby B Pro Tools M-Powered (Mac) 17 02-23-2009 04:44 PM
Pro Tools LE 7.4cs5 CPU overload issue LindsayJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-29-2008 02:41 PM
CPU Overload. Can't resolve issue. Theecomer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-01-2008 12:09 AM
PT7 Rewire overload issue DrBackshots Pro Tools M-Powered (Mac) 0 11-12-2007 04:33 PM
cpu overload 6.0 Dan Downs Pro Tools TDM Systems (Mac) 11 07-03-2003 01:56 PM
