My HD Native Thunderbolt disappeared from the Playback Engine in the middle of the night. It worked fine from February until now.
ProTools Ultimate and HD Driver were uninstalled and reinstalled. Did not work. MCU reset. Did not work. FPGA reset. It worked for 10 minutes after the firmware of the unit was reinstalled by ProTools. And then the unit disappeared again... (I tried to reset the FPGA again but it does not work now.) The unit has the red LED on. System Info > Hardware > Thunderbolt : The unit is detected. DigiTest : Not detected. Audio Midi Setup : Not detected. Playback Engine : Not detected. Digidal.kext. Loaded YES. iLok with Digilink I/O is connected. Mac Studio M1 Max. Ventura 13.2.1. ProTools Ultimate 2023.6. HD Native Thunderbolt with HD I/O (We have a second unit for our second room. I've connected it and it is immediately recognized. So it seems related to the HD Native TB unit, not the computer.) I am out of answers.
Simon G. BAP Audio |
having the same issue with magma express 3T chassis after I installed 2023.6. Rolled back to 2023.3 and still a no show for HDX in the audio output & session
Using a MB Pro 2019, Ventura 13.4, HDX via thunderbolt to symphony I/O mk II. Magma chassis still responds to the cpu starting up and shutting down so the hardware doesn't seem to be the issue. HD Driver?... |
And the issue with 2023.6 is known about, talked about in multiple (other) threads on DUC with more info.. and requests from Avid for folks to please file support cases/provide more info. Roll back the HD Driver to 2023.3 will get you going.
e.g. see this thread: https://duc.avid.com/showthread.php?t=424886
Maybe a mod can round up all the threads on HD driver problems on 2023.6 |
Rolled back and still no magic.
Mac Studio M3 Ultra / ProTools Ultimate / Symphony I/O MKII / Magma Express 3T/ HDX / macOS Sequoia 15.4.1 (24E263) |
I must add that the update did not cause my problem. Everything was working fine and it happened out of nowhere in my case. (I did not try to roll back though.)
Has anyone had luck getting their Native TB seen again? I also have the same problem with one of our Native TBs.
I've moved it to another computer running PT 2022.10 and still not seen by PT, DigiTest, etc. It is seen by the computer though. Why would it work fine one day and stop the next? |
Im having the same problem! Intried EVERYTHING in the avid support page, and still nothing. I connected the unit to my laptop, and it doesn’t work in it either. Just from one moment to another, it stopped working 🙃
Same Problem for me now on 24.10.2 on Mac OS 14.7.4. Anyone find a solution? I've tried everything except for the FPGA reset
Greetings,
I just looked at this here on my M1 Max MacBookPro running macOS Sonoma 14.7.4 with HDNTB + Pro Tools Ultimate (and HD Driver) 24.10.2 and don't have any problems. Have you done the necessary dance with the HD Driver and necessary security on macOS? https://avidtech.my.salesforce-sites...tion-on-macOS? Please check your System Information (see grabs below) to check the status of the HD Driver: https://www.dropbox.com/scl/fo/xwht3...=pu1pw9qu&dl=0 Do you know if the two different units in question had different firmware loaded? best, Jeff |
HD Native not seen for Playback Engine Selection | danhera | Pro Tools | 3 | 10-11-2022 04:34 PM |
HD Native Thunderbolt Engine is not being retained when selected as Playback Engine | antonis | Pro Tools HDX & HD Native Systems (Mac) | 0 | 01-08-2022 01:07 PM |
Playback Engine not seeing HD Native Omni | rabinrocks | Pro Tools HDX & HD Native Systems (Mac) | 15 | 04-26-2021 06:50 AM |
HD Native I/O does not show in playback engine | Kevn Blvk | Pro Tools HDX & HD Native Systems (Win) | 5 | 12-31-2017 12:50 PM |
PT 9.0.5 Native has problem with playback engine | JoeM | Pro Tools HDX & HD Native Systems (Mac) | 2 | 12-04-2011 06:08 AM |
