Le mbox2 install error
So originally on another forum, I posted about an error I was getting when i opened my Protools regarding a driver error, so I was given some steps to uninstall some addtl items that may have been missed by the uninstall process. I did that everything was going great. I go to install Protools and its installs the drivers and everything fine, then its all the way to end on the status bar, its install documentations, then I get an error box that pops up "Feature Transfer Error" and the box includes this info:
Feature: String is not attached Component: Documentation-Essential File: E:/Protools LE installer\data2.cab Error: incorrect function then i can only hit OK and I hit Ok and protools doesnt install and all of my previous sessions' icons show like they can't find the program. none of the icons show up in my start menu, etc...any ideas?! help |
Heres an update, I just tried to install it on my laptop a different computer and again it goes thru fine til the end with the documentation and I get the same kinda error "File Transfer Error" Except the info is a little different this time:
Feature: ***IS_STRING_NOT_ATTACHED Component: Documentation - Essential File:E:/Protools LE Installer \data2.cab Error: Data Error (cyclic redundancy check). Does this mean theres something wrong with the acutal disk?! HELP |
Make sure you have the right protools, i use vista and had to download a special version for everything to work. The disc not working on 2 PC's brings to mind some past PC issues. In my experience it would sound like either you have a scratched or rare but possible bad disc. If it is a bad disc and there are no overt signs of damage from the user then you should be able to mail your original disc into digidesign for a replacement, most software companies are aware that the occassional bad disc appears and they usually have some sort of disc replacment process. Hope everything works out for ya.
how to install Mbox2 LE 7 on Windows 7 | Hotep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-06-2011 07:51 AM |
Why install Pro-Tools to install drivers for Mbox2 | bigbobbysd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2010 07:42 AM |
Mbox2 Pro has gone unresponsive after software install - help! | svman8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-07-2008 11:07 PM |
MBOX2 pro no sound after XP SP3 install | ngsq12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-07-2008 02:44 PM |
Install mbox2 without pro tools on PC | DickT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-17-2007 09:46 AM |
