Transpose
I will keep this simple. I have 1 Audio note which I'd like to Transpose.
1. I Highlight the note 2. I Choose Event > Event Operations > Transpose 3. I then change the 0 in the Octave or Semitone to a higher or lower value 4. the APPLY Button remains blue when I click it 5. nothing changes What am I doing wrong? Many thanks ahead of time. Dan Last edited by DanielZ; 12-05-2016 at 01:06 PM. |
Re: Transpose
Event operations are for MIDI, not audio.
You can use a plugin (track-based on the inserts or an Audiosuite plugin), or you can use Elastic Audio. The monophonic algorithm can't be used to alter the pitch with EA.
Re: Transpose
Ah! Thank you.
However, two years ago I did the same process—but I have no idea which Menu I used—and I know it wasn't Elastic Audio. Two years ago I Highlighted an Audio notes—choose from a Menu which I can't remember—and a similar box opened up, asking me if I want to change pitch by a semi tone or an octave. It had an APPLY button, and it worked. Is there some other place besides Event operations and Elastic Audio where I can do what I am desiring? |
Re: Transpose
You likely used a Pitch plugin, but Elastic Audio is likely to give a better result. Enable Elastic Audio using the Polyphonic option. Highlight the note or clip you want to shift and separate it. Right-click on the clip and select Elastic Properties. That will bring up the window where you can enter the amount of shift. It USUALLY works quite well within 1-2 steps in either direction. For my money, the best pitch changer is Serato Pith 'n Time
Re: Transpose
Actually I didn't use a plugin…but I will use Elastic Audio for what I want to correct. I only need to correct in cents.
Many thanks for your help. Dan |
MIDI bug - Transpose | Firechild | macOS | 6 | 03-27-2020 07:42 AM |
Transpose Chords... | andrum | Pro Tools 10 | 20 | 02-16-2020 07:49 AM |
transpose | Jel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-19-2009 08:44 PM |
How do I transpose.... | Elton Hyland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-05-2007 10:32 AM |
transpose in audio HOW???? | Mano | Tips & Tricks | 2 | 12-24-2001 12:13 AM |
