Old 04-18-2013, 01:47 PM
lynx lynx lynx lynx is offline
Default Plugins on "factory reset" change sound???
How is it poosible that plugins (Q10, PT7band, Waves Deesser) change the sound even though everything is reset to zero? I can hear that the sound is degraded a bit in the highs, and it sounds a bit different alltogether! I toggle bypass and it sounds different. I have PT 7.3 with DV toolkit 2. I am moving to a dubbing stage next week, they have PT8 TDM and an AMS NEVE DFCII. Should I use plugins at all? Is it about RTAS version or what? Tnx for any help or similar experience!
Martin.
Old 04-18-2013, 02:19 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Plugins on "factory reset" change sound???
It has almost always been the case that sending the audio into a plug will decrease the volume slightly.... I know it seems strange but it happens with all my plugins... I believe it has something to do with going from session bit rate to Pro Tools engine rate to Pro Tools processing rate to 64 bit plug in engine and then back again....
Maybe some of the other guys are more informed on this process and why exactly this happens...
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 04-18-2013, 05:43 PM
Tnx a lot for this. That is what i thought, it must be similar to analog stuff, it goes trough some digital algorithms which changes sound. I dont't want the mathematics, I just want plugs to sound good. Do you know if I can change from RTAS to TDM without loosing automation, and if TDM sounds better?
Old 04-19-2013, 12:49 AM
JFreak's Avatar
JFreak JFreak is offline
Two reasons;
1) not all plugins are bit transparent. this means that nothing is done to the signal unless moving a knob from its initial position. it might be desired features or a design flaw but there you go.
2) it is always the case that when you insert a plugin it changes processing in the mixer. even if you added 0 to the signal that is still a calculation, and with floating point engine there will always be slight rounding errors, or differences, even if you add zero.
Therefore, the vanilla mixer always sounds most open, and any plugin you insert, or any routing you make, slightly degrades the sound. Very slightly and usually inaudibly, but still, theoretically what I just said is true.
Which brings us to the conclusion that less plugins is more sound. The reason why channelstrips are golden
Janne
Old 04-30-2013, 05:09 AM
Tnx a lot for this, now some of my "internal" philosophies and thinking about digital sound make more sense. I'm sure for the internal architecture of PT11 programers and engineers thought a lot about this
Old 04-30-2013, 10:19 AM
mattpete's Avatar
mattpete mattpete is offline
The original post in this thread mentions "PT7band" as a plug-in that changes sound in the factory reset position. I'm going to guess that the EQ III 7-band plug-in is the plug-in in question.
EQ III should not alter the sound in a factory reset condition. This is very simple to test by doing phase cancellation.
There are many other plug-ins that do change the sound just by being instantiated. These are usually "analog" style plug-ins that attempt to simulate the behavior of analog devices.
Matt Peterson
Avid Audio
PT 9.0.2 "loud pop and No Sound" problem related to plugins and 002R bortraws macOS 18 08-17-2015 03:21 AM
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
Cannot find "Factory Bundle" Plugins on Instal Disc skizzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-05-2010 03:16 PM
Is there a mix window "reset" to zero out plugins/ routing? MarkB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-23-2009 09:14 PM
None of my "factory" plugins show up in ProTools 8 villagechurch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-15-2009 01:59 PM
